Showing that (m n) + (m n-1) = (m+1 n).
  • Thread starter Thread starter Matthewkind
The discussion revolves around proving the identity (m n) + (m n-1) = (m+1 n) for positive integers m and n, where n is at most equal to m. The problem involves understanding binomial coefficients and factorials.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the definitions and properties of factorials and binomial coefficients. There are attempts to express (m n-1) in terms of (m n) and questions about simplifying expressions with common denominators. Some participants express confusion over the factorial notation and how to manipulate it correctly.
The discussion includes various attempts to clarify the relationships between factorials and binomial coefficients. Some participants have provided guidance on expressing terms and finding common denominators, while others are still grappling with the concepts and seeking further clarification.
Participants mention that the problem is from a textbook that does not provide sufficient explanations for the concepts involved, leading to confusion and frustration. There is also a sense of pressure among participants regarding their understanding of the material.
Matthewkind
Show that if n is a positive integer at most equal to m, then
I understand that (m n) = m!/n!(m-n)!. I'm not entirely sure how to figure out (m n-1) because the book I'm studying from never explains this. It merely explains factorials and then shows that (m n) = m!/n!(m-n)!; however, I can at least figure out by reasoning it out that (m n-1) = m!/(m-n+1)!(n-1)!. However, I cannot understand how the next step goes.
If we're adding m!/n!(m-n)! and m!/(m-n+1)!(n-1)! then I'm at a loss. The book says that the common denominator is n!(m-n+1)!, but I don't understand that. And the numerator comes out to be m!(m-n+1)+m!n?! This I just cannot understand! I've turned this problem over in my head for over and hour and still nothing! Please help!
This problem is from Serge Lang's 'Basic Mathematics' book. Chapter 1 - Numbers >> Rational Numbers >> Problem 7, part d.
Since you have the two terms on the left expanded try expanding the individual terms.
Your book should say that n!= n(n-1)(n-2)(n-3)...x3x2x1 right?
Well this can be written in a simpler manner, n!=n(n-1)!
See if you can simplify and bring both terms to a common denominator.
The book doesn't say anything about how n! = n(n-1)!. But that confuses me. I'm new to factorials and the binomial coefficient, so I'm a little confounded at the moment. How is n! = n(n-1)! a simplification of n! = n(n-1)(n-2)(n-3)...x3x2x1? :O
What I mean to say is how can you drop all of those other terms?
Also, if I write n! as n(n-1), then I get: m!/n(n-1)(m-n)! + m!/(m-n+1)!(n-1)!. I still can't quite make both denominators fit... I'm sorry for bothering you so much over a simple problem like this... I promise I'm trying. I think I'm just cracking under pressure.
Hmm... Even if I can get both denominators to become the same, how does the numerator end up as: m!(m-n+1)+m!n?! If they have a common denominator, shouldn't I be able to just add m! and m! together?
If you don't understand why n!=n*(n-1)! then you are cracking under pressure. That's the most basic thing about factorials. 3*2*1=3*(2*1). So 3!=3*2!.
Oooooh. I see! Sorry. XD I get how n! = n(n-1)!. Goshhhh. How silly.
So then m! = m(m-1) as well. So I can also set m! = m(m-1) as both numerators. But there are still some steps I seem to be missing. Blargh, what am I missing?! ;___; And why is this only introduced as a problem with no explanation?
I've been working through a bunch of different proofs and maybe I just need a break. I'm a bit discouraged that I don't understand what I'm doing when it comes to this part, but maybe it's alright. I just really want to be a theoretical physicist and it certainly is silly that such problems are slowing me down!
Ok then the rest of it goes the same. Express (m, n-1) and (m+1, n) as some factor times (m,n). Then show you have an identity.
I'm already nineteen and I'm still struggling with this stuff! Is it even possible for me to grasp differential geometry and tensor analysis in my lifetime at this rate?!
I don't understand what you mean. Where are you getting (m, n-1) and (m+1, n)? ;__;
Becoming a theoretical physicist involves a number of challenges and this isn't the greatest of them by a long shot. It's not alright if you can't do this. Do it.
Oh, sorry. I meant it's alright if I take a break to cool my head. XD No, I won't leave any stones upright in this area!
I'm getting them from your problem statement. Don't you remember?
Oh, the commas confused me. The way it's written there were no commas. I see. Let me try re-starting the problem.
(m, n) + (m, n-1) = (m+1, n). That's what I'm supposed to prove. So (m, n) = m!/n!(m-n!) and (m, n-1) = m!/(m-n+1)!(n-1)!. If I expand it, then I get: m(m-1)/n(n-1)(m-n)! + m(m-1)/(m-n+1)!(n-1)!. However, then I get stuck.
I know that (m+1, n) = (m+1)!/n!((m+1)-n)!. But I can't get to this because I am still not sure what to do after I hit what was mentioned above...
Can you show, for example, that (m,n-1)=(m,n)*n/(m-n+1)? It's a pretty simple extension of n!=n*(n-1)!.
How do you do that? (m,n-1) = m!/(n-1)!(m-n+1)!. (m,n) = m!/n!(m-n)!.
m!/n!(m-n)! multiplied by n/(m-n+1)? Where does that part come in? I mean, if (m,n) + (m,n-1) = (m+1, n), then wouldn't (m+1, n) - (m,n) = (m,n-1)? I'm so completely confused!
I can't take it anymore. I'm losing my mind. I need to stop and come back to this later. I don't even have any more hair to pull.
Thanks for trying to help me. I learned a bit about the nature of the problem (which was never even touched upon in the book for some reason...).
You can easily express factorials in terms of the factorial of a quantity that differs by 1. E.g. (n-1)!=n!/n. (m-n+1)!=(m-n)!*(m-n+1). It will probably look a lot easier when you come back to this.
Yes! Thank you so much! I believe I have solved the problem!
I first expanded the problem so that (m, n-1) + (m, n) = (m+1, n) is m!/n!(m-n)! + m!/(n-1)!(m-n+1)! = (m+1)!/n!(m-n+1)!.
Next I took the four terms of all denominators: n! (m-n)! (n-1)! and (m-n+1)! and multiplied them by each term to cancel out the fractional forms. I'm left with:
m!(n-1)!(m-n+1)! + m!n!(m-n)! = (m+1)!(m-n)!(n-1)!. So I have to get both of these sides equal, right?
Next, I expanded what I thought was necessary in order to factor out the correct terms.
m!(n-1)!(m-n+1)(m-n)! + m!n(n-1)!(m-n)! = (m+1)!(m-n)!(n-1)!. Then I factored.
m!(n-1)!(m-n)![m-n+1+n] = (m+1)!(m-n)!(n-1)!.
Then I added the two n terms together.
m!(m-n)!(n-1)![m+1] = (m+1)!(m-n)!(n-1)!. Finally I multiplied m! and [m+1] to get:
(m+1)!(m-n)!(n-1)! = (m+1)!(m-n)!(n-1)!
I know that I'm pretty silly for not being able to do this, but I am just now embarking on my mathematical quest. I finished this earlier and it looked to me like beauty. I wonder: do you all feel this way or am I being unnecessarily sentimental? I felt like crying with joy.
But you're right. I was being so close-minded at the time. I wonder why getting so worked up inhibits my ability to solve a problem logically. :/
  • · Replies 19 ·
  • · Replies 61 ·
9K
  • · Replies 29 ·
