Why Do We Square the Deviation in Least Squares Regression?
The discussion revolves around the least squares regression method, specifically focusing on the expression for deviation, F(m,b)=∑(y_i - f(x_i))^2, where f(x_i) is assumed to be linear. Participants are exploring the reasoning behind squaring the deviations and the implications for finding the best fit line through a set of points.
  • Participants discuss the derivation of partial derivatives with respect to m and b, questioning the correctness of their expressions and the implications of missing negative signs. There is also exploration of how to set up equations based on these derivatives to find m and b.
Some participants have provided guidance on correcting expressions and clarifying the relationship between the variables. There is an ongoing exploration of the system of equations derived from the partial derivatives, with participants attempting to solve for m and b while considering the implications of their findings.
Participants express uncertainty regarding summation notation and the implications of constants versus variables in their equations. There is also a mention of the need to avoid cancellation of terms in the equations derived from the partial derivatives.
ElijahRockers
http://www.math.tamu.edu/~vargo/courses/251/HW7.pdf
Given a set of points (xi,yi) and assuming f(xi) is linear, the deviation measured is F(m,b)=[itex]\sum_{i}^{n}(y_i - f(x_i))^2[/itex]. There are a few different questions about this from the link above.
I'm not sure why the expression [itex]\sum_{i}^{n}(y_i - f(x_i))^2[/itex] is squared.
Part one says to find the partials of this expression with respect to m and b. Here's my take on it. [itex]y_i[/itex] comes from the set of points, and [itex]f(x_i)[/itex] would be equal to [itex]mx_i+b[/itex].
Using the chain rule,
[itex]\frac{\partial F}{\partial m} = \sum_i^n 2x_i(y_i-(mx_i+b))[/itex]
[itex]\frac{\partial F}{\partial b} = \sum_i^n 2(y_i-(mx_i+b))[/itex]
Are these correct?
I can kind of see where this question is going. We can use these derivatives to sort of find the 'best fit', I'm guessing where the change in deviation is zero, that is probably the minimum deviation.
Sooo, dF. Does he mean both of the partials? Either one? Or are my expressions wrong to begin with. I haven't got any real experience with the summing notation, but I took a stab at solving for b by setting dF/db = 0.
[itex]b=\frac{\sum_i^n 2(y_i - mx_i)}{2n}[/itex]
That was just kind of a shot in the dark. If someone could give me a push in the right direction I'd appreciate it! Thanks :)
Are these correct?
They're both missing a negative sign, but otherwise, they're correct.
Both partials need to be equal to 0.
You're trying to obtain expressions for m and b that depend only on the x and y values. Your results for b still has m in it. The two equations ##\partial F/\partial m = 0## and ##\partial F/\partial B = 0## can be written in the form
\begin{align*}
A m + B b &= E \\
C m + D b &= F
\end{align*} where A, B, C, D, E, and F are combinations of the x and y values. You can solve this system of equations to get the results you want.
It's not. It is the terms [itex]y_i- f(x_i)[/itex] inside the sum that are squared. One reason for that square is to make sure that errors on opposite sides, positive and negative, do not cancel. More fundamentally (there are many ways to avoid errors canceling) it mimics the formula for distance in n dimensions, [itex]\sqrt{\sum (x_i- y_i)^2}[/itex].
Are these correct?
Ahhh I see that now. Thanks. But really though the negative sign won't affect my partials, because they are constant right?
So after more careful consideration, here's a second stab at it...
[itex]\frac{\partial F}{\partial b} = 0: \sum_i^n (mx_i + b) = \sum_i^n y_i[/itex]
[itex]\frac{\partial F}{\partial m} = 0: \sum_i^n (mx_i^2 + bx_i) = \sum_i^n y_ix_i[/itex]
But wouldn't the extra x_i cancel out in the second equation? Then I'd be left with two identical equations and that wouldn't help me.
And thanks Ivy, that clears things up a great deal. :)
The xi are different for each i, it's not a constant multiple for the whole equation. Here is a sample system of equations like what you have: suppose that x1=1, x2=2, y1 = 3, y2=4
1*m+b + 2*m+b = 3+ 4
(1*m+b)*1+2*(2*m+b)=3*1+4*2
Doing some algebra these equations are
3m+2b=7
5m+3b=11
Notice that these are not equivalent equations. Solving for m and b will in this case find you the line passing through the two points that are prescribed
Isn't that basically the same thing I have, just with the sums expanded?
Ok I took another shot...
[itex]nb + (\sum_i^n x_i)m = \sum_i^n y_i[/itex]
[itex](n\sum_i^n x_i )b + (\sum_i^n x_i^2)m = \sum_i^n y_ix_i[/itex]
Is that right? If so, could I solve by substitution?
Thanks for all the help.
Yes that's exactly what you need. Now solve it by your favorite method of solving 2 equations with 2 unknowns
  • · Replies 26 ·
