Understanding Induced Current and EMF in Electromagnetic Induction
  • Context: Undergrad
  • Thread starter Thread starter jsmith613
    Current
The discussion revolves around the concepts of induced current and electromotive force (EMF) in the context of electromagnetic induction. Participants explore the relationship between the direction of induced current and EMF, the conditions under which EMF can be induced in incomplete circuits, and the implications of these phenomena in practical scenarios such as antennas and inductors.
  • Some participants question whether the induced current flows in the same direction as the induced EMF, with references to the right hand rule for determining direction.
  • There is a discussion about the nature of EMF, with some participants suggesting that EMF is a potential difference that does not "flow" but exists across circuit components.
  • Concerns are raised about how EMF can be induced in a strip of wire that is not part of a complete circuit, with examples such as a car moving forward and inducing EMF in an aerial.
  • Some participants assert that induced EMF leads to current flow, while others argue that current flow depends on the impedance of the load connected to the EMF.
  • There are references to Lenz's law and the behavior of inductors, with discussions on how induced voltages oppose the current that created them.
  • Participants explore the implications of induced EMF in electric motors and the relationship between load and current draw.
  • Terminology clarification is sought regarding the difference between EMF and current, with some confusion expressed about the directionality of these concepts.
Participants express differing views on the relationship between induced current and EMF, with no consensus reached on whether they flow in the same direction or how to interpret the directionality of EMF. The discussion remains unresolved regarding the implications of EMF in incomplete circuits and the conditions under which current flows.
Participants highlight the importance of terminology in understanding EMF and current, noting that the relationship between magnetic flux, EMF, and current is complex and context-dependent. Some assumptions about circuit completeness and the nature of induced voltages are not fully explored.
jsmith613
Is an induced current (conventional current) in the same direction or in the opposite direction to the induced emf.
I ask this in relation to electromagnetic induction. We can predict the direction of the current using the right hand rule but how do I know the direction of emf?
Another question, related to this, is how could an EMF be induced (and hence a current be induced) in a strip of wire, such as an aerial, if it is not in a complete circuit? Surely the whole point of EM induction is to oppose the change in magnetic flux. If a current cannot be induced, how is this done? For example when a car moves forward, an EMF is induced across the ends of the aerial BUT there is no complete circuit
Thanks a lot guys!
Thanks a lot guys!
Hello,
To your first question: First, when you say direction of induced emf, do you mean polarity of the emf voltage?
Think of it this way, the emf reduces the amount of current flowing, or in the perspective of current, the decreasing change in current creates an increase in the amount of emf.
The equation for induction is:
[itex]EMF = -\frac{d\Phi}{dt}[/itex]
The minus sign shows that EMF opposes the change in flux.
In circuits with inductors, this looks like a voltage drop as the current passes through the inductor, so the current flows into the EMF's positive terminal, and out its negative terminal.
I hope that helps and makes sense.
DragonPetter said:
Hello,
Well I presume I mean polarity of EMF voltage although I am not quite sure of the difference :S
for the second paragraph, surely the induced EMF induces a current. if I take a strip of wire no current initially flows, so if I move it in a field and an EMF is induced a current HAS to flow (it cannot be reduced)
That's right. The Right hand rule tells you the direction of the EMF, which works even with an open circuit. The current direction follows from the EMF and the value depends on the load it drives..
What happens when current flows in an open wire? Do you think you can compare this to an antenna?
My point is that the EMF is what is induced. The Current is a secondary issue and depends upon the Impedance of the load. No current will flow in a short length of unconnected wire but there will be an EMF.
The theory of how an antenna couples to an EM wave is more involved because there is a varying E field as well as an H field. In the case of simple Magnetic induction, any E field is ignored because we aren't dealing with free space conditions.
well my first question really was to they flow in the same direction.
maybe I have misunderstood emf and that it doesn't flow?
It's a good thing to get the terminology right in things like this.
An EMF doesn't "flow"; it is a Potential Difference and exists 'across' to parts of a circuit. A current will flow as a result of an applied EMF.
PD is like a difference in heights. Things can fall from one height to another - like a current can flow.
Another thing to consider in the equation I first wrote out is that there is no current term. Magnetic flux can be dependent on a current, but it is not always the case. EMF is directly dependent on magnetic flux.
well surely one end of the emf is +/- and the other end 0
so let's say + is on the left and 0 is on the right. the emf will go from + to 0 (left to right).
if this is a closed wire, in which direction wil the current flow?
The same way current flows with any other + to - voltage source.
so from - to +
therefore, the direction of the induced emf can be worked out using the LEFT hand rule, right?
jsmith613 said:
so from - to +
How do you come to that conclusion?
EMF=−dΦdt and
I=EMF/Resistance
so where does your other sign change come from?
If you connect a battery, which way will the current flow? What's different for an induced emf?
induced voltages result in current flow that opposes the current flow that created the field that induced the voltage.
This is the reason inductors exhibit impedance. Apply a voltage across an inductor, current flows through it, which creates a magnetic field around it. Assuming AC voltage and that field varies with time depending on frequency, the magnetic field expands and collapses over time. Each time current passing through it increases, the field increases, each time the current collapses, the magnetic field collapses. the collapsing of the field has the opposite effect that the initial current-produced magnetic field did. It induces a voltage back into your inductor, this causes current to flow which bucks the source current. This is the nature of impedance in an inductor, and why it does not account for actual power loss as well, it just stores energy in a magnetic field.
This phenomena also accounts for CEMF inside an electric motor. The reason why motors draw more current bases on load, is because of the fact EMF is induced opposing source voltage. At slower speeds, less EMF is induced that bucks the source voltage, hence why a motor draws more current when loaded.
Research lenz' law
Right hand rule gives direction of current flow based on field direction and relative motion direction.
Left hand motor (lorentz' force) rule, right hand (faraday's induction) generator rule. Notice only your two middle fingers will oppose one another, which accounts for generator action in all motors, and all loading phenomena
basically, it depends how the magnetic field interacts with the conductor that is having a voltage induced in it.
If the field is expanding from the source, and collapsing on the conductor, the voltage is the opposite direction.
For a static field and relative motion of the conductor, use the right hand rule.
Absolutely BUT the 'back emf' is never greater than the initial induced EMF. Add the original EMF to the EMF generated by the induced current and it will always produce a current that is less it would have been but still in the 'right' direction . If you look upon it as being analogous to the force of reaction against you when you are pushing a massive object along, that reaction force is never great enough to move the object towards you.
[tex]\oint \vec{E} \cdot d \vec{l} = - \int \frac{d \vec{B}}{dt} \cdot d \vec{A}[/tex]
This is the equation for induction, just written out in more detail. On the right-hand side of the equation is an area integral, where the direction of the area vector is the normal to the surface. And on the left-hand side is a line integral over a closed path bounding the same area.
The convention in physics is that the line integral goes anti-clockwise around the area which it bounds. So from this, you can work out the direction of the electric field.
EMF=−dΦdt and
I=EMF/Resistance
well then as there is no change in sign I would presume therefore that EMF and current are in the same direction
Right. (Thank god - or nothing would work. )
yeah i totally agree, there has to be power lost during the transfer of energy, as well all the flux that the current created can not be linked, much is leaked.
I know you know this. :D
First, I simply thought that the induced voltage opposed a change in flux linkage (there does not need to be a current producing it - e.g: a permamnent magnet), right??
Also what happens if there is no circuit...no current...therefore no field. so why induce an EMF??
That's right.
No, the reason for flux production, is because of current flow. Voltage causes current flow, and current flow exhibits a magnetic field when it flows, the field occurs around the charge flow. So now imagine you have a magnetic field established, (as well as an electric one but we need not discuss it) so now faradays induction law... states that with relative motion between a conductor, and a magnetic field, we induce a voltage in said conductor. Now the induced voltage causes a SECONDARY current to flow.. it flows opposite the original current due to laws that flemmings hand rules illustrate.
With no current, therefore no field, there is no induced EMF.
Im not sure but I think you might not realize this:
Two circuits, that are close physically, can induce voltage in one ANOTHER... because of the fields produces.. this is very true when the circuits are in harness' or liquatite or are in close proximity, and often, the conductors are wrapped with a shield that is grounded, so the magnetic fields cut the shield, induce the current in that instead, and the current flows to ground rather than mess with other signals.
well, there has to be a FIELD, a permanent magnet as you said will exhibit one, but in an electric circuit, you need current flow to establish a magnetic field. Which is what we are talking about here.
no take my example post #1
a car moves in the Earth's magnetic field (NO circuit OR current). an EMF is induced in the aerial.
how does this therefore fit..how does an opposite mag field get produced
didn't see that post.. yeah
In that case there is a change in flux in the observational frame of the car. This is indistinguishable from the current in an electromagnet being changed - so an EMF will be induced.
as some one here said, think of a battery!
It isn't a complete circuit but once connected, current will flow from and to end.
there still exists POTENTIAL for current to flow
I am confused? are you saying the EMF and current in this situation are the same??
I agree with FOIWATER's last post, there doesn't necessarily need to be an induced current. It's just that the EMF is always such that the induced current would decrease the change in magnetic flux.
  • · Replies 42 ·
