Pendulum with two springs and a stick
  • Thread starter Thread starter dat240
    Pendulum Springs
The discussion revolves around a pendulum system that includes a stick and two springs, focusing on determining the natural angular frequency of small oscillations. The problem involves concepts from mechanics and oscillatory motion.
  • Mixed
  • Participants explore the relationship between spring forces and pendulum motion, with attempts to combine equations from both systems. Questions arise regarding the setup of the problem, the role of torque, and the integration of angular displacement with spring oscillation equations.
Some participants have offered insights into the nature of simple harmonic motion (SHM) and the necessary conditions for it to apply to angular systems. There is an ongoing exploration of how to relate displacement in the spring system to angular displacement in the pendulum setup.
One participant expresses a lack of familiarity with angular SHM, indicating that they are seeking conceptual understanding rather than direct answers. The discussion reflects varying levels of experience with the underlying physics concepts.
dat240
A pendulum consists of a stick of length L and mass M that is pivoted about its center, and attached to a pair of springs of stiffness k. As shown in attached pic, the springs are symmetric about the pivot, and the distance between them is l.
a) Find the natural angular frequency ω of this pendulum's small oscillation
I think, T = 2π(m/k)^(1/2) and ω = 2π/T but am not sure.
I can see how stored energy is being passed between the springs but am not sure how to setup the problem. Do I need to use COM/torque since mass is distributed throughout the stick? Thanks for your input.
Not sure if my attachment worked... going to try to post it again here.
where is the attempt?
I feel like I'm just clutching at equations, but I'll try.
I saw that the physical pendulum equation was T = 2π(I/mgh)^(1/2).
For a thin rod about axis through center perpendicular to length, I = (1/12)ML^2
Since I'm not dealing with gravitational potential, I wanted to substitute the spring energy equation (1/2)kx^2 for mgh.
So, T = 2π(ML^2/6kx^2)^(1/2)
But now that I've written it out, I see that I've added the variable x, which isn't a given. My problem is that I have spring oscillation equations and pendulum equations, but I don't understand how to combine them.
Seems to me you have lack of practise. Have you studied angular SHM?
No. I'm an intro physics student, and we just got to SHM yesterday. I've reviewed my book and notes but am not yet at a level where I understand much about it.
I'm not looking for free answers. I'm looking for help understanding the concepts so I can apply them in this and other problems. I don't know what else to say. If I knew much about angular SHM, I wouldn't be asking for help.
Most physics questions are not just formula based. You have to solve it.
Now let's talk about SHM.
Simple harmonc motion is that motion where accelaration is proportional to 'negative of displacement'. When we take angular displacement the anglular acceleration is taken.
Now the best way to solve a SHM question is to displace the body by a distance small 'x' or small 'theeta'(in angular SHM) and then show the forces on the body and hence find its accelation. You will get accelaration as a function of 'x' or 'theeta'(for angular SHM). And if you get accelaration as negative of displacement then only it is SHM.
And if you get so then just use the eqn
-(omega)^2*x=a
In case of angular SHM the eqn becomes
-(omega)^2*(theeta)=(alpha)
where alpha is angular acceleration
And remember the only diffrence betweeen linear and angular SHM is
1. 'theeta' for 'x'
2. torque for Force
3. 'alpha' for 'a'
4. moment of inertia(I) in place of mass(M)
-(omega)^2*x=aIn case of angular SHM the eqn becomes
1. 'theeta' for 'x'
2. torque for Force
3. 'alpha' for 'a'
Thank you. I'm away from my notebook right now, but I will think about what you said and give it another (hopefully better) shot when I get home.
Okay, so let me try again.
Tilting the rod a bit shows that the springs are always applying equivalent restorative forces. They are also applying equivalent torques since the forces are symmetrical about the point of rotation. The torques act in the same rotational direction.
So,
2τ = Iα
2kx(l/2) = Iα
kxl = Iα
From here, I wanted to plug in I = (1/12)ML^2 for the rod's moment of inertia, and α = (ω^2)∅ per your suggestion. While this does allow me a way to solve for ω, the x and ∅ variables don't cancel from what I can tell. And shouldn't ω be constant throughout?
you are very near. Try to find a relation b/w 'x' and 'theeta'
