Linear Fractional Transformation (Mobius Transformation) from circle to line
The discussion revolves around finding a linear fractional transformation that maps the unit circle |z|=1 onto the line defined by Re((1+i)w)=0, which corresponds to the y-axis in the complex plane.
  • Participants discuss the necessity of selecting points on the circle and the line to ensure a unique transformation. There is consideration of how many points to choose and the geometric implications of mapping a circle to a line.
The conversation is ongoing, with participants exploring different strategies for selecting points and questioning the symmetry of the points involved. Some guidance has been offered regarding the selection of symmetric points and the mapping process, but no consensus has been reached on the exact points to use.
There is some confusion regarding the definitions of inside and outside of the circle, as well as the appropriate points to select for the transformation. Participants are also grappling with the implications of mapping points from the unit circle to the y-axis.
d2j2003
find linear fractional transformation that carries circle |z|=1 onto the line Re((1+i)w)=0
linear fractional transformation is of the form az+b/cz+b where ad-bc≠0
Re((1+i)w)=0 means that the line is just the y axis, but then I am unsure.. I think I might have to pick points and figure out the transformation that maps the points where i want them to go?
Yes, you do need to pick points!
Now the question is, how many points and how do you strategically choose them so the LFT you solve for is unique?
I would say 3 points.. But geometrically does the circle basically just unravel and sit on that line?
If that's the case I would have to pick a point that maps to the origin and then pick another that maps to infinity? And then I'm not sure about the third...
You can say that, yes. Every poit on your circle will map to a point on the line.
The way to tackle these types of problems is to map two symmetric points to two symmetric points, and then to map a boundary point to a boundary point. In this case your are sending a circle to a line. You need to choose two points that are symmetric to the circle (one inside of the circle, one outside) and send them to two points that are symmetric to the line you want to map to. Lastly, you want to map a point on the circle to a point on the line. This will force the new LFT to map that circle to that line.
You can pick ANY two symmetric points to the circle mapping to ANY two other symmetric points to the line as well as any point on the circle to any point on the line; the answer will be the same. Because of this, try to pick easy values to work with to make your life a bit easier.
For this problem since I am mapping from |z|=1 there is no inside and outside of the circle right? It is just the boundary that is being mapped.. So I would have to pick points from the boundary right?
I think I could map 1 to infinity and map -1 to 0 but after that I'm not sure..
Sorry for my late response, I was at work all day.
You have it backwards! Your circle is the unit disk. However, your two points of 1 and -1 are NOT symmetric to the unit circle, they are symmetric to the y-axis. I think you just mixed up the terms, you had the right idea.
Okay, so let's say your LFT is T(z). Set [itex]T(0) = -1 \text{ and } T(\infty) = 1[/itex]. Now you need one more point! Just take any point on the unit circle and map it to any point on the y axis! Solve for your LFT and you are done!
You can check yourself by picking any point on the unit disk, say, r. Then take T(r) and you will see that it will have no real part.
but I didn't think 0 and ∞ were on the circle |z|=1
They're not! Maybe I'm assuming too much, is your only method available to constructing LFTs to just map three points on a circle to three points on a circle? (remember line and circle are the same in this context) if that's the case, pick any three points on the circle and map them to any three points on the line.
I was suggesting a somewhat easier method. Have you gone over symmetric points yet? You map two symmetric points to two symmetric points, and then you map one point on the circle to one point on the line.
Can you tell me which way you are supposed to go about this?
I don't see anything in the chapter about symmetric points... so I'm assuming just 3 points to 3 points on the line.. but it seems like there would be more than one mapping... the answer the book gives is λ(1-i)[itex]\frac{z+1}{z-1}[/itex] so I'm just trying to understand it
