Showing that the range of a linear operator is not necessarily closed
The discussion centers on demonstrating that the range of the linear operator T: ℓ² → ℓ, defined by T(x) = (x₁, 1/2 x₂, 1/3 x₃, ...), is not closed. The solution involves constructing a sequence xₙ = (1, 1/√2, 1/√3, ..., 1/√n, 0, 0, ...) that is square summable, leading to T(xₙ) converging to a sequence y that is not in the range of T. This is established by showing that T⁻¹(y) results in the harmonic series, which is not square summable, confirming that y does not belong to the range of T.
  • Understanding of linear operators in functional analysis
  • Familiarity with the spaces ℓ² and ℓ
  • Knowledge of convergence and limits in sequences
  • Concept of square summability and harmonic series
  • Study the properties of linear operators in functional analysis
  • Explore the differences between closed and non-closed ranges of operators
  • Learn about the implications of square summability in sequence spaces
  • Investigate the relationship between convergence in ℓ² and the behavior of linear transformations
Mathematicians, students of functional analysis, and anyone studying linear operators and their properties in sequence spaces.
SP90
Let [itex]T: \ell^{2} \rightarrow \ell[/itex] be defined by
[itex]T(x)=x_{1},\frac{1}{2}x_{2},\frac{1}{3}x_{3},\frac{1}{4}x_{4},...}<br /> <br /> Show that the range of T is not closed<br /> <br /> <h2>The Attempt at a Solution</h2><br /> <br /> I figure that I need to find some sequence of [itex]x_{n} \rightarrow x[/itex] such that [itex]T(x_{n})[/itex] is in [itex]\ell^{2}[/itex] but [itex]T(x)[/itex] is not.<br /> <br /> I figured that if [itex]x=(\sqrt{1}, \sqrt{2}, \sqrt{3},...)[/itex] then [itex]T(x)[/itex] is the harmonic series, which is not square summable. The problem is, I can't think of any square summable [itex]x_{n}[/itex] which converge to that [itex]x[/itex]. <br /> <br /> I have a feeling that I'm taking the wrong approach to this. The thing is, I think the operator [itex]T(x)[/itex] must be bounded since [itex]k_{i}^{2} \geq \frac{1}{i^{2}}k_{i}^2[/itex]. Maybe I should be looking for some [itex]x_{n} \rightarrow x[/itex] such that [itex]T(x_{n})[/itex] converges to something other than [itex]T(x)[/itex].[/itex]
I thought if I took [itex]x_{n}=(\frac{n}{1},\frac{n}{2^{2}},\frac{n}{3^{2}}...)[/itex], that would work, since [itex]x_{n} \rightarrow \frac{n\pi^{2}}{6}[/itex]. It's clear that [itex]T(x_{n})[/itex] exists for all n, but [itex]x_{n}[/itex] itself diverges. But then obviously the definition of the range being closed is that when [itex]T(x_{n})[/itex] has a limit, that limit is in the range. Obviously since [itex]T(x_{n})[/itex] diverges there's no criteria broken by this.
I've solved this now, no need for a response, but if anyone ever comes across a similar problem here is the solution:
Take [itex]x_{n}=(1, \frac{1}{\sqrt{2}}, \frac{1}{\sqrt{3}}, ..., \frac{1}{\sqrt{n}}, 0, 0, 0 ,0,...)[/itex]
Obviously, as a series with a finite number of non-zero terms, it is square summable. Likewise [itex]T(x_{n})[/itex] also exists and is the sequence [itex]x_{n}=(1, \frac{1}{2\sqrt{2}}, \frac{1}{3\sqrt{3}}, ..., \frac{1}{n\sqrt{n}}, 0, 0, 0 ,0,...)[/itex]
Then [itex]T(x_{n}) \rightarrow y[/itex] where y is the infinite sequence of these. When each term is squared and the sum taken, we get the sum of reciprocal cubes. This is bounded by the sum of reciprocal squares, so it is square summable, so the sequence [itex]T(x_{n})[/itex] is convergent. But [itex]T^{-1}(y)[/itex] is the infinite sequence of reciprocal square roots. When each term is squared, the sum of these is the harmonic series, which is not convergent. So [itex]y[/itex] doesn't belong to the range of [itex]T[/itex] (since there is no [itex]x[/itex] in [itex]\ell^{2}[/itex] such that [itex]T(x)=y[/itex])
  • · Replies 105 ·
13K
  • · Replies 17 ·
