Solve Laplace Transform for y'' + w^2y = cos(t), y(0) = 1, y'(0) = 0
The discussion focuses on solving the differential equation y'' + w^2y = cos(t) using the Laplace Transform method. The initial conditions are y(0) = 1 and y'(0) = 0, with the constraint that w^2 is not equal to 4. Participants detail the steps to derive Y(s) and discuss the challenges of performing partial fraction decomposition, specifically addressing the expression s/(s^2 + 1)(a) and the correct setup for the partial fraction expansion.
  • Understanding of Laplace Transforms and their properties
  • Familiarity with solving second-order differential equations
  • Knowledge of initial value problems in differential equations
  • Experience with partial fraction decomposition techniques
  • Study the application of Laplace Transforms to solve initial value problems
  • Learn about partial fraction decomposition in the context of Laplace Transforms
  • Explore the properties of the Laplace Transform, including linearity and shifting
  • Practice solving differential equations with varying initial conditions and parameters
Students studying differential equations, mathematicians, and engineers looking to deepen their understanding of Laplace Transforms and their applications in solving initial value problems.
GNRtau
y'' + w^2y = cos(t)
y(0) = 1
y'(0) = 0
w^2 not equal to 4
Laplace integral, transform via table/memory...
Y(s) = F(s) or whatever you like to use
s^2Y(s) - sy(0) - y'(0) + w^2Y(s) = s/(s^2 + 1). Right side is L(cos(t))
Group together, you get. (s^2 + w^2)Y(s) = L(cos(t)) + s For simplicity's sake, s^2 + w^2 equals a.
Divide by left side. L(cos(t))/a + s/a = Y(s). The second term is just cos(wt), so that part is done.
I'm a little stuck on how you expand the partial fraction here. I've never really done it before Laplace transforms, so I'm having some problems doing it in situations that are a little different like this.
s/(s^2+1)(a). So I would do As+B/(s^2 + 1) + Cs+D/(a)? After that, multiply by both sides, but from there I get a mess... a(As+B) + (s^2+1)(Cs+D). I plugged in 0, got Bw^2 + D = 0. Is there a more efficient way to do this(I'm sure the people here would know a way), or do I just to need to grind through the algebra? Sorry about the notation if unfamiliar.
Thanks for all the help in advance. I appreciate it.
Assuming what you wrote for the partial fraction expansion means this$$
\frac{As+B}{s^2+\omega^2}+\frac{Cs+D}{s^2+1}$$it looks correct. Yes, you just have to grind it out. Sometimes you can shorten the work by equating powers of ##s## or picking clever values of ##s## after multiplying it out. I don't know any nice shortcut.
  • · Replies 18 ·
