New Reply
work and frequency caused by mutual potential energy
Share Thread Thread Tools
Apr15-12, 06:32 PM   #1
Hi everyone,
Here is the question:
The mutual potential energy of a Li+ ion and an I- ion as a function of their separation r is expressed fairly well by the equation U(r)=(-Ke^2/r)+(A/r^10), where the first term arises from the Coulomb interaction, and the values of its constant are:
K= 9x10^9 N-m^2/C^2, e=1.6x10^-19 C
The equilibrium distance rnot between the centers of these ions in the LiI molecule is about 2.4 Angstrom. On the basis of this info,
(a) How much work in eV must be done to tear these ions completely away from each other?
(b) Taking the I- ion to be fixed b/c it is so massive, what is the frequency in Hz of the Li+ ion in vibrations of very small amplitude? Take the mass of Li+ as 10^/26
3. The attempt at a solution
I used the U(r) formula to find the work, but how can you find the work without knowing what A is?
For part b, i found the second derivative of the U(r) function to get the value of the spring constant, k. Again, how do we know what the value of A is?
Thanks for any and all help!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Apr15-12, 11:22 PM   #2
Hi phys17,
Never in all my years have I encountered a 1/r^10 term in a potential. Am I reading this correctly - you mean 'one over r to the power of ten'? I guess there's nothing actually wrong with that - you can write down any wild potential you want - but I don't think anyone here is going to be able to guess what that term could possibly be or what the 'A' is without some more information. That being said, your ideas on how to deal with the vibrations via a spring constant are very good - well done, I think that is correct! Is it possible that your instructor meant for you to leave things in terms of A? Because with the information interpreted literally and as given, that's the best you can do. Sorry I don't have more insight, but I think we need some more information or your instructor needs to explain what this term is supposed to be.
Hope this helps,
Bill Mills
Apr16-12, 08:55 PM   #3
Mentor
Quote by phys17 View Post
Hi everyone,
Welcome to PF
Here's a hint: what must be true about U(r) at the equilibrium position r=rnot=2.4Å?
Quote by billVancouver View Post
Hi phys17,
I imagine it's an approximation for when then two ions are close together. Somewhat akin to the 1/r12 term in the Lennard-Jones potential typically used for neutral atoms.
Don't forget, we are given the equilibrium position.
Hope this helps,
Bill Mills
Apr17-12, 12:32 AM   #4
Thanks so much, guys!
I figured out part a today. To find A, I found the derivative of U(r), set it equal to 0 and then solved for A, since that is the unknown. From there, it's easy to find the work - just substitute all the numbers in.
I ran into trouble for part b. Since the spring constant is the second derivative of U(r), I evaluated at that second derivative. BUT, 2.4 Angstrom converted to meters is a really small value, so when I do A/r^10, I just get 0.
Apr17-12, 06:46 PM   #5
Mentor
There are a couple of way around that, that I can think of:
1. Use eV and Å for units, instead of J and m. The numbers should be closer to "regular size" that way, i.e. neither extremely small or extremely large in magnitude.
or
2. Work in scientific notation. Use the calculator to work the between-1-and-10 part of the numbers, and use pen and paper to work the 10xxx's
If you're still stuck, by all means post your work here. Otherwise these suggestions are just a stab in the dark at helping you out.
EDIT added: #3 - use Google as your calculator, it can handle 1/(2.4Å)10:
http://www.google.com/#hl=en&sclient...w=1280&bih=638
New Reply
Thread Tools
Similar Threads for: work and frequency caused by mutual potential energy
Thread Forum Replies
energy=work, but how does work = electric potential energy? General Physics 4
Work-Energy Theorum: Spring potential energy vs Kinetic Energy Introductory Physics Homework 4
Potential difference, electric potential energy and work Introductory Physics Homework 1
Using addition theorem to find the mutual potential energy of the 2 electrons in heli Calculus & Beyond Homework 1
how does frequency depend on the potential energy? Classical Physics 2
