How far from the left end should the fulcrum be placed?
  • Thread starter Thread starter Mdhiggenz
    Fulcrum
The discussion focuses on determining the correct placement of a fulcrum for a uniform bar with masses attached at both ends. The bar measures 48.7 cm in length, with a mass of 0.105 kg on the left end and a mass of 0.150 kg on the right end. The correct distance from the left end for the fulcrum placement is 31.8 cm, which was derived using the center of mass approach rather than the static equilibrium equation initially attempted by the user. The user’s initial calculation was incorrect due to an oversight in accounting for the forces acting on the system.
  • Understanding of static equilibrium equations
  • Knowledge of center of mass calculations
  • Familiarity with torque concepts
  • Basic principles of mechanics involving forces and moments
  • Study the concept of center of mass in composite systems
  • Learn how to apply static equilibrium equations in various scenarios
  • Explore torque calculations and their applications in physics
  • Investigate common mistakes in balancing problems involving multiple masses
This discussion is beneficial for physics students, educators, and anyone interested in mechanics, particularly those studying static equilibrium and center of mass concepts.
Mdhiggenz
A 0.105-, 48.7--long uniform bar has a small 0.055- mass glued to its left end and a small 0.150- mass glued to the other end. You want to balance this system horizontally on a fulcrum placed just under its center of gravity.
What I did was used the static equilibrium equation and set the pivot to be at the far right in order to cancel out those forces.
m2=mass of the bar
m1= mass of the ball to the far left
x the distance to the left from the Fulton
l= length of the bar
I set clockwise to be the positive direction
Ʃτ=0→ m1gx+m2g(l/2) solved for x and got
x=-m2(l/2)/m1
The answer I got was incorrect the correct answer is 31.8 cm and they used a different approach from mine.
Cheers
m2=mass of the bar
x=-m2(l/2)/m1
Cheers
I would use centres of mass.
The Centre of Mass for the Bar is clearly at its centre, and its mass is given.
You can find where the Centre of Mass of the two masses can also be found in the usual way.
You then find the Centre of Mass of those two Centres of Mass.
m2=mass of the bar
x=-m2(l/2)/m1
Cheers
When doing the rotations as you did, you account for mass of Bar - at a distance half way out, the little mass all the way out [both anti-clockwise] and the fulcrum force equal to sum of both masses plus the bar. I think you have left some weight forces out.
10K
