Why a two-slit experiment with electrons is evidence electrons are waves?
The discussion revolves around the two-slit experiment with electrons and its implications for understanding the wave-particle duality of electrons. Participants explore the evidence that suggests electrons exhibit wave-like behavior in this context.
  • Participants discuss the nature of interference patterns and how they relate to wave behavior, questioning the interpretation of electrons as classical particles. There is also a focus on the wavefunction and its role in quantum mechanics.
Some participants have provided insights into the nuances of the two-slit experiment, highlighting the distinction between wave-like behavior and the classification of electrons as waves. There is an ongoing exploration of the implications of these observations without reaching a definitive consensus.
Participants note the potential confusion surrounding the interpretation of quantum mechanics and the importance of understanding the distinction between wave-like behavior and the nature of electrons themselves. There is also mention of the urgency related to exam preparation, which may influence the depth of discussion.
nukeman
I'm just trying to prepare a study pack for my final. I am curious about something I have been reading over in my textbook. Can someone please explain this for me?
"Be able to explain why a two-slit experiment with electrons is evidence that electrons are waves"
Because an interference pattern (like the one you get in the two-slit experiment) only occurs when the objects interfering are waves, not particles.
Hi nukeman,
One of the key points of a two-slit experiment is that you can fire a single electron at a time at the slits, and if you don't detect which slit it goes through, you will still observe an interference pattern built up over time. This doesn't make sense if the electron is a classical particle going through one slit or the other; only by interpreting it as a wave could this be possible.
In reality, the 'wavelike' behavior here is that of the electron's wavefunction, the probability distribution of where it could be. But a lot of the amazing / confusing results of early QM come from the conflation of what an object 'is' with its wavefunction. Anyway, this point is probably too subtle for your test, so don't worry about it; see the first paragraph about behavior observed when firing single electrons at a time :)
Hope this helps,
Bill Mills
For the sake of (being pedantic) completeness - the two slit experiment for electrons does not demonstrate that electrons are waves - exactly. It demonstrates wave-like behavior for electrons (which were not normally expected to display wave-like behavior) and so provides evidence for the general applicability of quantum wave mechanics... which predicts this behavior yea even for lumps of matter.
The experiment does not tell us if the electron is a wave but that some of it's behavior is best modeled using the same math we normally use to describe waves. This is so close to he same thing, and so long-winded, that we don't normally bother with the distinction - but it's there, an important one, and creates a lot of confusion in students if they don't bear it in mind.
@irfan104 - you are a tad off topic: how did you get on?
If you are having this sort of trouble so close to an exam, then it is probably too late: you will find the method in your notes. You should already know it and have practiced it through the course.
  • · Replies 35 ·
  • · Replies 36 ·
10K
  • · Replies 28 ·
  • · Replies 26 ·
