Potential energy of a system (gravity)
The potential energy of a system consisting of four equal particles, each with mass M, positioned at the corners of a square with side length d, is calculated as ep = - \frac{G M^2}{d}*(4 + √(2)). The gravitational force is defined by F(r) = - \frac{G M m}{r^2} * ur, while the potential gravitational energy is given by Ep(r) = - \frac{G M m}{r}. To determine the potential energy, one must compute the work required to separate the particles to infinity, with the negative of that work representing the system's potential energy.
  • Understanding of gravitational force and potential energy equations
  • Familiarity with the concept of work in physics
  • Knowledge of gravitational constant G and its application
  • Basic algebra for manipulating equations involving square roots
  • Study the derivation of gravitational potential energy equations
  • Learn about the concept of work done in moving particles in a gravitational field
  • Explore the implications of potential energy in multi-particle systems
  • Investigate the role of the gravitational constant G in various contexts
Students studying classical mechanics, physicists interested in gravitational systems, and educators teaching concepts of potential energy and gravitational interactions.
jjr
Show that the potential energy of a system which consists of four equal particles, each with mass M, that are placed in different corners of a square with sides of length d, is given by
ep = - [itex]\frac{G M^2}{d}[/itex]*(4 + √(2))
The gravitational force F(r) = - [itex]\frac{G M m}{r^2}[/itex] * ur
Potential gravitational energy Ep(r) = - [itex]\frac{G M m}{r}[/itex]
I'm having a hard time achieveing an intuitive comprehension of how one might solve this problem. As far as I can understand, they're asking how much work would be done if all the particles moved into the center? I'm not sure if I should figure out the work it would take to bring each individual particle into the center one at a time, all at once, or if I need to approach this in some other way.. Any hints would be greatly appreciated
Thanks in advance,
J
The gravitational potential is zero at infinity. You need to calculate the work needed to take the system apart, to move the particles one by one to infinity. The negative of that work is equal to the potential energy of the system.
ehild
Of course! Thanks:)
  • · Replies 43 ·
  • · Replies 23 ·
