amuron
- 32
I'm trying to build a low profile rolling flat cart. I am running into issues with calculating the material thickness needed to prevent warping, as well as total failure.
The consisits of a 4 foot x 8 foot sheet of plywood of tbd thickness. On the bottom of the cart will be 12 tandem wheel 2" castors spaced equally across the surface. As such, the carts height will remain below 4" from rolling surface to the top.
The cart will be loaded with a fairly uniformly distributed load of 2000 lbs. Each castor is rated at 200lbs. The fairly uniform load is across the total surface, but there will be 12"-18" gaps between points of load contact. This is a lot less safety factor than I'm comfortable with under normal cirumstances. Otoh, the duty cycle will be very low.
What I need to do is determine the proper plywood thickness to use, such that it doesn't warp between castors, nor catastrophically fail. I'm assuming somewhere there exists detailed information on plywood loading vs thickness and species, both static and dynamic. Unfortunately, a quick google seach didn't identify a useful site.
The castors will roll on a maple floor, with 4"X12" floor joists underneath, such that the floor loading should not be an issue.
Its been 20 years + since my statics classes... any help to get my back on track would be appreciated.
Ron
Ron
