Differential Readings upon Reversing Polarity on MEMS Gyroscope
Reversing the current in a MEMS gyroscope can lead to damage due to the specific voltage supply requirements of the chip. The gyroscope operates on a vibrating structure that typically uses alternating current (AC) to function properly. In applications such as truck stability detection, the gyroscope's wings resonate at a specific frequency, and reversing the current disrupts this resonance, potentially affecting the accuracy of the readings.
  • Understanding of MEMS gyroscope operation and design
  • Knowledge of alternating current (AC) and direct current (DC) principles
  • Familiarity with voltage supply specifications for electronic components
  • Basic concepts of angular momentum and resonance in mechanical systems
  • Research the voltage supply requirements for specific MEMS gyroscope models
  • Learn about the principles of AC and DC current in electronic devices
  • Explore the role of resonance and Q factor in MEMS gyroscopes
  • Investigate the applications of MEMS gyroscopes in automotive stability systems
Engineers, electronics hobbyists, and students interested in MEMS technology, particularly those focusing on gyroscope applications in automotive and stability systems.
Free Radical
Hi, y'all;
This will likely be a simply question for most of you, but I am still something of a neophyte (yes, yes, starting off with the whole education thing in my 30's -- egad!) but if I were to reverse the current running through a MEMS gyroscope, what would be the outcome in the figures it returns -- both digital and analog?
I'm not quite sure what you mean by the question.
First, a MEMS chip is designed to run on a specific voltage supply, and so reversing current would probably damage it. There is a "front end" or interface section of these chips that interpret the signal from the MEMS structure and send it out in a format you can easily interface to.
Secondly, most MEMS gyroscopes are vibrating/resonating structures, and so I would guess the current would be AC and go in both positive and negative directions on each cycle. The one I'm thinking of in particular is used in trucks to detect if a truck is tipping over, and this one has 4 wings rotating around an axis at a resonant frequency, and as the angular momentum changes the wings fall out of resonance (Q factor changes). In order for the wings to resonate, you probably want to drive them with an oscillator that will have alternating current in both directions.
11K
  • · Replies 31 ·
9K
  • · Replies 31 ·
9K
10K
