Trying to prove dual of there are at least tree points on every line
The discussion revolves around proving the dual statement of "there are at least three points on every line" within the context of projective geometry. Participants explore the implications of various incidence axioms and extensions, questioning their interpretations and relationships.
  • One participant suggests that if only one point exists and no lines are present, then the axioms become vacuously true, potentially countering the theorem being proved.
  • Another participant agrees with the initial concern regarding the implications of having only one point.
  • Clarifications are made regarding the wording of axiom (4), with suggestions that it could be rephrased to indicate the existence of a line and a point not on that line.
  • Some participants discuss the necessity of additional conditions, such as the existence of four points, to support the axioms in question.
  • There is a debate about the interpretation of axiom (3) concerning distinct lines and points, with differing views on whether it implies intersection in projective geometry.
  • Recommendations for alternative textbooks are provided, with some participants expressing interest in better resources for understanding projective geometry.
Participants express differing interpretations of the axioms and their implications, particularly regarding the existence of lines and points. There is no consensus on the best way to phrase the axioms or the necessity of additional conditions, indicating ongoing debate.
Some participants note that the original statements and their interpretations may not fully capture the intended meanings from the textbook, leading to potential misunderstandings. The discussion reflects a range of assumptions and conditions that are not universally agreed upon.
This discussion may be of interest to students and scholars of projective geometry, particularly those exploring the foundational axioms and their implications in geometric proofs.
A_B
trying to prove dual of "there are at least tree points on every line"
Hi,
Assuming the propositions of incidence:
(1) on any two distinct points is at least one line.
(2) on any two distinct points is at most one line.
(3) on any two distinct lines is at least one point.
and the extensions
(4) not all points are on the same line.
(5) There are at least three points on every line.
I am asked to prove the dual of (5), that is, "there are at least 3 lines on every point."
(The duals of all other statements above have already been proven.)
Perhaps there is something I'm missing (and that's the reason for posting) but it seems to me that if only one point exists (call it P) and no lines then (1), (2), (3), (4) and (5) are all vacuously true. So this would present a counterexample to the sought-after theorem.
thanks!
A_B
i agree with you.
Can you word (4) more precisely?
Hi, thanks for the replies
(4) could be alternatively worded as
(4) There is no line such that all points lie on that line
And since in the case where there is only one point there is no line, this is vacuously true.
I've been looking at places other than the book I'm working through, and the condition
(A) there exist four points, no three of which are on the same line
is often added in a similar set of axioms. See for example http://www.math.cornell.edu/~web4520/CG3-0.pdf
Now it is obvious that (4) follow from (A), and according to the text linked to above, (5) will also follow (exercise 6 (a)).
I ran into this problem when beginning to work through "An Introduction to Projective Geometry" by O'Hara and Ward : http://archive.org/details/introductiontopr033583mbp.
Is anyone familiar with this book?
Would anyone suggest a better book?
Thanks,
A_B
rejoice!
If we take (1), (2) and (3) be be true and we consider the 'rival' extensions:
I. : (4) , (5) AND (6) THERE EXISTS AT LEAST ONE LINE
II. : (A)
Then I and II are equivalent.
I => II
since there is a line (a) (6), there are 3 points (A, B, C) on that line (5). But no line contains all points (4), so there must exist a fourth point (D) not on the line. But then there exists a line (b) on which lie the points A and D (1). The line (b) can not lie on either (B) or (C), since if it were, it would be equal to line (a) (2). So only points (A) and (D) lie on (b) so there must exist a point (E) distinct from all other points so far mentioned that is on (b). The points (B), (C), (D) and (E) satisfy II..
II => I
II => (4)
follows immediately
II => (5)
an exercise for the reader, hehe...
It is an exercise (6 a) here: http://www.math.cornell.edu/~web4520/CG3-0.pdf.
II => (6)
also follows immediately.
Clearly though, (6) is "yet another addition" to the extension, only there to exclude simple cases. The alternative II. seems preferable.
Still interested in better book suggestion though.
A_B
That's one way, but what was intended by the textbook? Another way it could be worded is
(4) There exists a line and a point not on that line​
I have copied (4) "not all points are on the same line" directly from the book, I don't think that "There exists a line and a point not on that line" is equivalent to (4) as stated, thoughit does indeed solve the problem and it may indeed have been the meaning intended by the author.
Anyways, the book says "For the present they will suffice, but later more definite propositions will be substituted" about these extensions, so I suppose I shouldn't be too troubled by this problem.
A_B
I assume that
Is not saying that there is a point that exists on BOTH lines, since that would be incorrect for parallel lines (or any lines in 3D that do not intersect)
phinds said:
I assume that
That's exactly what it's saying. The notion of parallel lines is a euclidean (or affine) one, in projective geometry, all lines have a point in common. Think of a drawing of a railway track, while the rails never meet (Euclidean), the lines that represent them in the drawing do meet on the horizon. The drawing is a projection.
That's not exactly the same thing since the original statement does NOT imply that a line exists. Perhaps "if L is a line then there exit point P not on line L".
i recommend you get a better book, hartshorne, hilbert...
9K
15K
