Accelerating charged particles emit EM waves?
The discussion centers around whether an electron, when accelerated in one dimension, emits electromagnetic (EM) waves. Participants explore the nature of the electric and magnetic fields associated with a moving charge and the conditions under which radiation occurs, considering both uniform acceleration and changes in speed.
  • One participant asserts that accelerating charges emit EM waves, questioning if an electron accelerating in speed alone would do the same.
  • Another participant suggests that the scenario of uniform acceleration is controversial and may depend on interpretations of radiation.
  • Concerns are raised about misconceptions regarding the nature of electric fields around a moving electron, particularly the idea of a constant electric field pointing towards the electron.
  • Questions are posed about whether an increasing magnetic field due to the electron's acceleration would induce an electric field, and how this relates to the production of EM waves.
  • There is a challenge to the notion that the electric and magnetic fields would not change orientation continuously, with a participant arguing that they do change over time due to the motion of the charge.
Participants express differing views on the nature of the electric field around a moving electron and the conditions under which it emits EM waves. There is no consensus on whether simply increasing the speed of an electron in one dimension results in the emission of EM waves, and the discussion remains unresolved.
Participants reference the retarded nature of electric fields and the finite speed at which they propagate, indicating that assumptions about the behavior of fields may not be straightforward. The discussion also touches on the complexities of uniform acceleration and its implications for radiation.
plazprestige
I know that if you have alternating current in a wire, it will produce electromagnetic waves since the electric and magnetic field change direction continuously as the wave propagates, and that the wave direction, orientation of the E component, and orientation of the B component will all be mutually perpendicular.
However, this acceleration arises from changing direction of charged particles, not speed.
My question is this:
If I were to accelerate an electron by increasing its speed in one dimension (+x), would that electron emit EM waves?
The electron will have a constant electric field pointing towards itself, and its magnetic field will be going into the page in the 1st quadrant and going out of the page in the 4th quadrant, and the magnitude of the magnetic field will be increasing.
I can visualize the mutually perpendicular B and E waves, but they would not be changing orientation continuously since it isn't AC current. Would this still be an EM wave?
Hello,
The answer to your question in bold is: yes!
(For the case of uniform acceleration (at all times!) it's a bit controversial, the theory is not clear on its prediction, or perhaps it depends on what you mean by radiation in that case, but the example is pathological so never mind for now)
Generally: an accelerating charge radiates.
I don't really follow what you say next though. I think you're having some misconceptions. For example "The electron will have a constant electric field pointing towards itself" is not really correct: the electric field is retarded (due to the fact that the electric field spreads out at a finite speed), e.g. see http://www.cco.caltech.edu/~phys1/java/phys1/MovingCharge/MovingCharge.html
Also "but they would not be changing orientation continuously" doesn't sound correct: the electric field and magnetic field are changing in time, aren't they? This is simply due to their source changing in time.
I'm a bit confused then. An electron will have electric field lines pointing toward itself (since convention has positive test charges in the field). As the electron speeds up, its electric field will not change directly since its charge is the same, but its magnetic field will increase in magnitude.
Would this increasing magnetic field induce an increasing electric field?
Even if the answer to the above is yes, I still do not see how an electron simply speeding up will produce EM waves in the nature of which alternating current produces EM waves.
"I'm a bit confused then. An electron will have electric field lines pointing toward itself"
Did you not fully read my last point? I addressed this misconception.
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 20 ·
