Would a Leftward Shift of the Supply Curve Cause a Shortage
The discussion revolves around whether a leftward shift of the supply curve would result in a shortage. Participants explore the implications of such a shift in the context of economic models, price adjustments, and consumer behavior, addressing both theoretical and practical aspects of supply and demand.
  • Some participants note that a leftward shift of the supply curve could lead to a shortage if the quantity demanded exceeds the quantity supplied, but this is contingent on various factors.
  • Others argue that the definition of shortage depends on the context, such as whether the supply reduction is due to rationing or price changes, and how these factors influence welfare losses or gains.
  • A participant raises the question of whether a deliberate reduction in supply, which causes prices to rise, can be classified as a shortage.
  • Some discuss the role of demand elasticity and consumer behavior, suggesting that the nature of the product (essential vs. non-essential) affects the outcome of a supply shift.
  • One participant emphasizes that the new equilibrium after a supply shift will depend on the dynamics of consumer behavior and market adjustments, suggesting the need for a dynamic model to fully understand the implications.
  • Another participant mentions that the new equilibrium will be established at a higher price and lower quantity, indicating a shift in market conditions.
Participants express differing views on whether a leftward shift of the supply curve results in a shortage, with no consensus reached. The discussion highlights various interpretations of economic models and the conditions under which shortages may or may not occur.
Participants acknowledge that the definition of shortage and the implications of a supply shift can vary based on assumptions about consumer behavior, product necessity, and market dynamics. The discussion also touches on the limitations of static models in capturing the complexities of real-world scenarios.
domyy
Hello guys,
I have a quick question:
Would a leftward shift of the supply curve result in a shortage?
There are important differences.
If the supply is being reduced because of rationing, or because of prices (or generalized costs)?
Typically these "shortages" are measured in terms of welfare losses or gains.
Take a firm selling very few of a particular product and because of it, it´s price is high.
So we´re talking about a deliberate reduction in supply which causes price to increase, in a sense. That results in a leftward shift of the supply curve. Now, can I say there´s a shortage after this shift?
That is the supply side, What do we know about the demand side?
Are the consumers able to substitute this particular product? Do they must necessarily consume a limited amount of this product? (is it water? or XBOX?).
Depending on the demand, and supply, you will get different welfare gains or losses.
If the product is not essential, then prices are likely to lead to less consumption, and you could Consumer's Surplus to get an idea of the utility loss.
Also, what do you mean by "shortage"?
It seems to imply that consumers must meet a quota in their consumption with regards to the good. I think this is reasonable for water, food, and other similar goods. However, for XBOXs, and such likely not.
Well, let´s say the company relies on the brand. People buy because of the name.
And people can afford it.
Hello,
A shortage occurs when the quantity demanded exceeds the quantity supplied.
If there's a shift of the supply curve to the left, and there are no price controls to impede adjustment, the market will move toward the equilibrium.ETA: No shortage would occur in this particular circumstance
Take stores selling very expensive handmade gala dresses. Because it´s handmade, there are very few of those around. Its scarcity causes the price of the dresses to rise.
With a leftward shift of the supply curve, demand will then be greater than supply, and that will cause price to rise. Would that be correct?
The issue is what the author wants to accomplish from his/hers economic model.
Yes the definition of shortage is demand exceeds supply. However, you must understand that this static models can only show what happens from one equilibrium point to another. Thus, if you change the price or you ration the product, you will get a new equilibrium point. Given those two equilibrium points you can "measure" the welfare gains or losses. That is what I am trying to get at. However, your welfare results will vary depending on the policy that changes the equilibrium points.
If you care about the dynamics (how consumers change to between equilibrium points), then you should consider a dynamic form of the problem.
There are other issues that may be of interest depending whether strategic behavior should be considered.
Oh I guess I understand. So you´re saying the new equilibrium is set at the the high price and which is established in this new equilibrium point now.
What I am trying to understand is what happens to the overall view of the graph.
There is a new intersection of the supply and demand curves.
That becomes the new equilibrium.
http://www.colorado.edu/Economics/courses/econ2020/section6/gifs/fig62.gif
Increase in price, decrease in quantity
Pyrrhus is not incorrect, but I believe he may be delving too deep into the question.
I'm assuming a simple comparative statics model that one would analyze in a principles class.
Yes. I am trying to ascertain domyy's purpose. I guess an easier way would have been to ask is this just your standard textbook problem?.
The problem is like I said from the beginning depends on what you think moving the supply function will affect the consumers. Thus, yes if you move it to the left, you get the classical result, and you can calculate the consumer surplus because of the change of price, and there is your answer.
More interesting problem will be to consider a case where the Consumer MUST meet a certain quota, and then the result varies.
Thanks!
Thank both of you. You guys were a great help :)
  • · Replies 40 ·
  • · Replies 74 ·
