Parametrization question for my Intro. to Higher Math Class
The discussion revolves around a problem involving the parametrization of the paths of two objects, A and B, moving in opposite directions on a straight line. Participants explore how to find the point of intersection and the time it takes for the two objects to intersect, engaging in both mathematical reasoning and conceptual clarification.
  • Homework-related
  • Participants discuss the initial positions and velocities of objects A and B, with A starting at P(A)=(-40, -20) and B at P(B)=(190, 980).
  • Some participants express confusion about the meaning of the parameterization of the paths, particularly the vectors V(A) and V(B).
  • One participant proposes a specific parameterization for object A, suggesting a natural choice for t=0 and t=1, while noting that there are infinite parameterizations possible.
  • Another participant outlines the equations for the positions of A and B over time, seeking to find their intersection.
  • There is a discussion about the method of plugging in values for t to find the intersection, with some participants expressing frustration over not getting closer to an intersection point.
  • One participant suggests rewriting the equations to clarify the parameters used for A and B, proposing to use different symbols for the parameters to avoid confusion.
  • Another participant calculates an intersection point but later receives feedback that the two paths do not intersect based on the derived equations.
  • Participants engage in back-and-forth corrections regarding the intersection calculations, with one asserting that the paths do not intersect based on the equations derived from their parameterizations.
There is no consensus on whether the two paths intersect. Some participants believe they have found intersection points, while others argue that the equations derived indicate that the paths do not intersect at any point.
Participants express uncertainty regarding the definitions and implications of the parameterizations used. The discussion includes unresolved mathematical steps and varying interpretations of the problem setup.
vanitymdl
Two objects A and B are traveling in opposite direction on a straight line. At t=0 A and B are at positions P(A)=(-40, -20) and P(B)=(190, 980), respectively. If additionally, their paths are parameterized by directions V(A)=(3,5) and V(B)=(-24, -40), respectively. Then,
a) find the point where these two object intersect.
b) how long does it take these two objects to intersect?
Have you tried unwrapping the definitions?
I'm not sure I understand your layout; what do P(A)=(-40,-20), and V(A)=(3,5) mean, given that movement is along a line?
hi vanitymdl! :wink:
show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
I, for one, am not certain what you mean by "parameterized by directions V(A)=(3,5) and V(B)=(-24, -40)".
I imagine you mean that A contains the point (-40, -20) and extends parallel to the vector 3i+ 5j but there are still and infinite number of parameterizations. The most "natural" would be to take t= 0 at point (-40, -20) and t=1 at (-40+ 3, -20+ 5)= (-37, -15). That would be given by x= -40+ 3t, y= -20+ 5t. But, as I said, there are an infinite number of parameterizations giving that same line.
I attached a picture of the problem, it's number six.
How should I even attempt to start this problem?
I know that my parameters for A are:
x = -40 + 3t
y = -20 +5t
and for B are:
x = 190 -24t
y = 980 -40t
now how can I find where the two intersect?
O.K, so, at time t=0:
A is at (-40,-20)
B is at (190,980)
At time t=1:
A is at (-40+30,-20+5)=(-10,-15) , B is at ( 166,948),etc.
Now, by intersecting we mean that A,B must have the same x- and y- coords.
How do we figure out when the coords. are trhe same?
I was plugging in different values of t from 1-12 but I noticed that the points weren't getting any nearer to each other. Is there another way then trying to plug in different values for t
Well, how can you tell if/when A,B have the same x- and the same y- values? You know how their respective x-, y- values are defined. When do the curves y=t^2 and y=t meet? How can you tell?
Sorry, I need to leave know.
well if y=t^2 and y=t then they meet at the origin (0,0) but I don't see how that's going to help me?
Can you see how to formally figure out?
What if we had y=t-1 and y=t^2-4 ?
I don't mean to be obtuse about this; I am just trying to lead you to the answer and not just give it to you.
You want :
190-24t= ?
980-40t=?
No no I appreciate what you are trying to do, thank you.
Well no wonder why I wasn't getting anything near it...
but I got (45.375, -995) for that intersection
x = -40 + 3t
y = -20 +5t
and for B are:
x = 190 -24t
y = 980 -40t
First, recognize that while x and y are coordinates in the plane, the "t" in each set of equations simply mark points on the line and are NOT necessarily the same in both sets. So that you don't confuse them, call the parameter in the second set "s" rather than "t".
So we have x= -40+ 3t and y= -20+ 5t for one line and x= 190- 24s, y= 980- 40s for the other. They will intersect where the x and y values on one line are the same as on the other line: x= -40+ 3t= 190- 24s and y= -20+ 5t= 980- 40t, two equations to solve for t and s. Once you have found them, put either into the appropriate x, y equations to find the coordinates of the point of intersection.
It ultimately comes down to the definition of 'A,B intersecting'. Intersecting means they are in the same location in the plane. This means that , they will be in the exact same coordinates.
okay okay I'm getting confused even more confused to how the find the intersection...From what i was doing the A and B never intersect?
I've gone through t=100 and I'm still not seeing anything near an intersection. Its getting further and further apart
Ah I finally got an intersection its approximately it's (-14.4444, 91.1111) can someone check that for me?
No, that isn't correct. The two equations (using t for one parameter and s for the other as I suggested before) are
-40+ 3t= 190- 24s and -20+ 5t= 980- 40s which we can rewrite as
24s+ 3t= 230 and 40s+ 5t= 20. If we multiply both sides of the first equation by 5 and the second by 3 we get
120s+ 15t= 1150 and 120s+ 15t= 60.
The left hand sides are the same but the right hand sides are not. The are NO values of s and t that make both equations true. As you were told before, these paths do NOT intersect.
  • · Replies 86 ·
9K
  • · Replies 21 ·
  • · Replies 93 ·
17K
