Thread Closed
El Cheapo Number Game
Share Thread Thread Tools
Jan16-05, 03:37 AM   #1
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Follow the sequence of tsteps listed below, if you have the patience, and a calculator
#0. Think of a positive integer (the smaller, the better for you)
#1. Add 30 to it
#2. Multiply this by 7
#3. Write this number in the form 10X + Y, where [itex]0 \leq Y \leq 9 [/itex] (eg : N = 345 => X = 34, Y = 5)
#4. Find A = |X - 2Y|
#5. If A > 9 then write A = 10X + Y and repeat #4, else go to #6.
#6. If A is any of 0,1,2,3,4 then find B = A+10, else if A is one of 5,6,7,8,9 then B=A+3
#7. Find the B'th letter of the alphabet (1=>A, 2=>B, 3=>C, ...)
#8. Think of a country beginning with this letter, in the Eastern Hemisphere (Europe, Africa, Asia, Oceania/Australia)
#9. Take the last letter in this country's name
#10. If possible, pick the smallest positive number whose spelling begins with this letter (T=>2, F=>4, S=>6), else pick the number corresponding to the position of this letter in the alphabet (a=>1, B=>2, C=>3, D=>4, G=>7, etc.)
#11. Add 4 to this number.
#12. Multiply this by any whole number less than 10.
#13. Write this number, D as 10X + Y, just like before
#14. Find E = |3X - Y|, and as before, repeat until E < 10
#15. Multiply E by anyinteger you choose.
Your final answer is..... :: ZERO ? ::
Debunk the magic (if it worked ).
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Jan16-05, 12:20 PM   #2
Answer:
Well, it doesn't. #4 can result in a negative number, as in:
10 (+30)
40 (*7)
280 (10X+Y)
X=28, Y=0 (X-2Y)
28 (10X+Y)
X=2, Y=8 (X-2Y)
-14
Jan16-05, 02:07 PM   #3
Recognitions:
Thanks for pointing that out. I forgot to put in a modulus sign (absolute value).
Jan16-05, 04:57 PM   #4
Aha, I got it.
The key is that the number at step 2 is divisible by 7. If you take a number N and multiply it by 7 to get M, you first multiply the ten's digit by 7. Then if you have one's place 0 in N you know that |X - 2Y| for M will also be divisible by 7. If the one's place in N is 1 then you add 0 to M's X and 7 to M's Y, so |X-2Y| will still be divisible by 7. Continuing in this fashion until you get to the one's place of N being 9, where you add 6 to M's X and 3 to M's Y, you find that |X-2Y| will always be divisible by 7 if M is divisible by 7.
So in the end you must get 0 or 7, which in either case comes to a J, for which you have Japan or Jordan, both ending in n. You then get 9, then 13. Checking every possible number to multiply 13 by, from 1 to 9, you find it always comes back to 0.
Jan16-05, 06:48 PM   #5
Recognitions:
Okay, that's a fair debunking.
Now how about trying to find something more elegant than the "checking every possible number" approach ? In other words, can you prove the conjectures for < the divisibility rules for 7 and 13 > that I've cooked up ? In fact can you do better and establish the existance of such divisibility rules for any number ?
Jan16-05, 07:50 PM   #6
Well, I did prove it for 7. I'll think about 13 later.
By the way, negative numbers all start with n ("negative three, negative four...") and there is no smallest negative number so technically it doesn't quite work.
Jan16-05, 09:32 PM   #7
Recognitions:
Quote by Bartholomew
Okay, let's settle this once and for all. Negative numbers are a figment of your imagination. They are a myth propagated by the "New Evil Geniuses About To Vaporize Everyone", a cartel of mathematical villains striving for global domination.
Jan17-05, 02:11 AM   #8
Well, you can do 13 similarly to how I did 7.
You start with some number written in decimal form AA...AB. To multiply it by 13 you first multiply the AA part by 13 and then the B (units) part by 13 and add them together. When B is 0, |3X - Y| will be divisible by 13 since it is just the A's multiplied by 13 * 3. When B is 1, it's the same as if B were 0, except that to 3X you must add 1 * 3 = 3, and to Y you must also add 3, so |3X - Y| comes back to the same value. When B is 2, it's the same as if B were 0, except that to 3X you must add 2 * 3 = 6, and to Y you must also add 6, so |3X - Y| comes back to the same value. And so on, until when B is 9, 13 * 9 = 117, so that to 3X you must add 11 * 3 = 33, and to Y you must add 7, so that |3X - Y| is 26 greater than what it would have been if B were 0, so it is still divisible by 13.
Jan17-05, 03:17 AM   #9
Recognitions:
Here's another proof I came up with : it's for a general case, and so can be used to generate a divisibility rule for any number.
Conjecture : Picking some particular multiple of N, and writing it in the form 10X + Y, the linear combination aX + bY that is equal to 0 or N determines the pair of coefficients (a,b) such that for any multiple of N expressed likewise, as some 10x + y, the linear combination ax + by will alway give a number that is divisible by N.
Proof :
Let the number for which we want to establish a divisibility rule be N.
Let's choose some multiple of N, say mN, where m > 0.
Write mN = 10X + Y, and let aX + bY = {0,N}
Then for any integer k , such that kN = 10x + y, we must show that ax + by is divisible by N.
So, we have :
[tex]10X + Y \equiv 0 ~~(mod~N) ~~~~(1)[/tex]
[tex]aX + bY \equiv 0~~(mod~N) ~~~~(2)[/tex]
[tex]10x + y \equiv 0 ~~(mod~N)~~~~(3) [/tex]
and we want to show that
[tex]ax + by \equiv 0 ~~(mod~N) [/tex]
From (1) :
[tex]10X \equiv -Y => 10bX \equiv -bY ~~(mod~N)~~~~(4)[/tex]
From (2) :
[tex]aX \equiv -bY ~~(mod~N)~~~~(5)[/tex]
From (4) and (5) :
[tex](10b - a)X \equiv 0 => a \equiv 10b~~(mod~N)~, X~not~div~by~N~~~~(6) [/tex]
Also, from (3) :
[tex]10x \equiv -y~~(mod~N)~~~~(7) [/tex]
Multiplying (6) and (7) :
[tex]10ax \equiv -10by => ax \equiv -by ~~(mod~N)~, 10~not~div~by~N~~~~(8) [/tex]
(8) is nothing but
which is the required result.
QED
What does all this mean ?
Let's take the case of 7. Pick a simple multiple of 7 to determine the coefficients...say 14. We want to find (a,b) so that 1a + 4b = 0 or 7. With a=4, b=-1, you get 0. Better still, a=-1, b=2, gives 7. So, if any multiple of 7 is written as 10x + y, the combination -x + 2y will always be divisible by 7. For instance consider 518, where x=51, y=8. |2y-x| = |16-51| = 35, which is divisible by 7.
For the case of 13, 3(1) - 1(3) = 0, so for all multiples of 13, |3x - y| will be divisible by 13.
Thread Closed
Thread Tools
Similar Threads for: El Cheapo Number Game
Thread Forum Replies
Help with game theory (specific knowledge in game theory probably not required) Calculus & Beyond Homework 4
Improving a Search Heuristic for symmetric number-board game Engineering, Comp Sci, & Technology Homework 0
Improving a Search Heuristic for symmetric number-board game Calculus & Beyond Homework 0
Do you purchase cheapo or the best of the best General Discussion 15
Simple number game Brain Teasers 5
