Could somebody confirm this answer for me please?
  • Thread starter Thread starter djames1009
The discussion confirms the solution for a particle of mass 2 kg subjected to a drag force defined by F(v) = -0.5v². The initial conditions are x(0) = 0 m and v(0) = 1 m/s. The derived expression for displacement is x(t) = 4(ln(t + 4) - ln(4)). Evaluating this at t = 4 yields x(4) = 4ln(2) m, confirming the calculations are accurate except for a minor notation error regarding the force equation.
  • Understanding of calculus, specifically integration and differentiation.
  • Familiarity with Newton's second law of motion.
  • Knowledge of drag force concepts in physics.
  • Ability to manipulate logarithmic functions.
  • Study the derivation of drag force equations in fluid dynamics.
  • Learn about the application of differential equations in motion analysis.
  • Explore advanced integration techniques, particularly for logarithmic functions.
  • Investigate the effects of varying mass on drag force and motion equations.
Students and professionals in physics, particularly those focusing on mechanics and fluid dynamics, as well as anyone interested in solving differential equations related to motion under drag forces.
djames1009
Could somebody confirm this answer for me please? :)
A particle of mass 2kg is subject to a drag force from the air: F(v)= -0.5v^2. The initial displacement of the mass is zero and the initial speed is 1ms. Find an expression for x(t) and hence work out x(4)
From the initial conditions we know that:
[itex]x(0)=0 m[/itex]
[itex]v(0)=1 m/s[/itex]
I'm going to keep using the notations v(t) and x(t) to try to remind you that v and x are functions of t, which is very important when doing calculus.
For a constant mass:
[itex]F(v(t))=ma=m\frac{dv(t)}{dt}=-0.5v(t)^2[/itex]
So:
[itex]\frac{dv(t)}{dt}=\frac{-0.5v(t)^2}{m}=\frac{-v(t)^2}{4}[/itex]
[itex]-\int\frac{1}{v^2}dv=\int\frac{1}{4}dt[/itex]
Integrating gives:
[itex]\frac{1}{v(t)}=\frac{t}{4}+c=\frac{t+4c}{4}[/itex]
[itex]\Rightarrow v(t)=\frac{4}{t+C}[/itex]
Since, from the second initial condition:
[itex]v(0)=\frac{4}{0+C}=1 m/s[/itex]
Then:
[itex]C=4[/itex]
Giving:
[itex]v(t)=\frac{dx(t)}{dt}=\frac{4}{t+4}[/itex]
Integrating with respect to t:
[itex]\int\frac{dx(t)}{dt}dt=\int\frac{4}{t+4}dt[/itex]
Gives:
[itex]x(t)=4ln(t+4)+b[/itex]
Since, from the first initial condition:
[itex]x(0)=4ln(0+4)+b=0[/itex]
Then:
[itex]b=-4ln(4)[/itex]
Which gives the final equation for displacement, x(t):
[itex]x(t)=4(ln(t+4)-ln(4))=4ln(\frac{t+4}{4})[/itex]
And:
[itex]x(4)=4ln(\frac{4+4}{4})=4ln(2) m[/itex]
Well everything looks great, except in the second line where you said 0.5 = 1/4.
Skipping units I think he said 0.5/m=1/4. Since m=2 kg this looks reasonable IMO.
  • · Replies 27 ·
  • · Replies 30 ·
