An unguided weapon is launched off a fighter aircraft flying at 500kts
  • Thread starter Thread starter sroy1313
    Aircraft Flying
An unguided weapon is launched from a fighter aircraft traveling at 500 knots (844 ft/s) at an altitude of 4,000 ft AGL. The weapon's initial velocity upon release is 10 ft/s, and it features selectable canister opening settings at various altitudes, including 1800 ft AGL down to 300 ft AGL. The canister takes 4 seconds to function fully, necessitating that its contents do not hit the ground before this time elapses. To determine the optimal canister opening setting, one must apply the equations of motion to calculate the maximum time the canister can remain airborne while ensuring its contents complete their functions.
  • Understanding of projectile motion equations
  • Familiarity with canister deployment mechanisms
  • Knowledge of basic physics concepts such as gravity and velocity
  • Ability to perform calculations involving time, distance, and acceleration
  • Study the equations of motion for projectile trajectories
  • Research canister deployment timing and mechanisms in military applications
  • Learn about the effects of altitude on projectile performance
  • Explore the principles of parachute deployment and wind drift reduction
Aerospace engineers, military tacticians, and anyone involved in the design and deployment of unguided munitions will benefit from this discussion.
sroy1313
An "unguided" weapon is launched off a fighter aircraft flying at 500kts
An "unguided" weapon is launched off a fighter aircraft flying at 500kts (844 ft/s) straight and level at an altitude of 4,000 ft above ground level. The weapon is released from the aircraft with an initial velocity of 10 ft/s (supplied by the bobm rack pistons). The weapon has several selectable canister opening settings controlled by a canister altimeter. These opening settings include 1800 ft AGL, 1500 ft AGL, 1200 ft AGL, 900 ft AGL, 700 ft AGL, 500 ft AGL, and 300 ft AGL. It takes 4 seconds for the canister contents to complete their function. It is desired that none of the canister contents hit the ground before completing their functions. (Note: once the canister opens, the subsystems deploy parachutes, in order to reduce wind drift, it is desired to open the canister as close to the ground as possible, still allowing for the contents to complete their functions.)
a) Select the proper equations to describe the flight of the canister, perform a study to recommend a canister opening setting.
I am unclear where to begin? I know that the first step is to draw a sketch, but after that I am not sure what I am supposed to be looking for?!
I'm pretty sure all you have to do is solve y = y_0 + v_0t -1/2gt^2 for t when y = 0, subtract 4 sec. and then plug back into the above equation in order to get the maximum time you could have in the air while still allowing the cannister to complete its functions. You could also equivalent solve y = y_0 + v_0(t-4) -1/2g(t-4)^2 = 0.
  • · Replies 43 ·
11K
9K
  • · Replies 17 ·
11K
  • · Replies 55 ·
15K
