Is π(L) a Submanifold of the Torus?
The discussion centers on the proof that the image of the line L under the canonical projection map π from ℝ² to the torus ℝ²/ℤ² is not a submanifold of the torus when the ratio b/a is irrational. Specifically, the user is attempting to demonstrate that π(L) is not locally Euclidean, concluding that every neighborhood of the point π(0) is disconnected. The user references John Lee's book for a more elegant solution, while also mentioning a brute force method utilizing the Hurwitz Theorem that ultimately provides a valid proof.
  • Understanding of submanifolds in differential geometry
  • Familiarity with canonical projection maps, specifically π: ℝ² → ℝ²/ℤ²
  • Knowledge of the concept of local Euclidean spaces
  • Acquaintance with the Hurwitz Theorem in mathematics
  • Study the properties of submanifolds in differential geometry
  • Learn about canonical projection maps and their applications in topology
  • Explore local Euclidean spaces and their significance in manifold theory
  • Investigate the Hurwitz Theorem and its implications in proving topological properties
Mathematicians, particularly those specializing in differential geometry and topology, as well as students seeking to understand the relationship between lines in Euclidean space and their projections onto manifolds.
jgens
I am trying to prove the following result: Fix [itex]a,b \in \mathbb{R}[/itex] with [itex]a \neq 0[/itex]. Let [itex]L = \{(x,y) \in \mathbb{R}^2:ax+by = 0\}[/itex] and let [itex]\pi:\mathbb{R}^2 \rightarrow \mathbb{T}^2[/itex] be the canonical projection map. If [itex]\frac{b}{a} \notin \mathbb{Q}[/itex], then [itex]\pi(L)[/itex] (with the subspace topology) is not a submanifold of [itex]\mathbb{T}^2[/itex].
I am having difficulty however showing that [itex]\pi(L)[/itex] is not locally Euclidean. From drawing a few pictures, I think every neighborhood of [itex]\pi(0)[/itex] is disconnected (which would be enough to complete the proof), but I am having difficulty showing this. Any help?
Look at p.158 of the book of John Lee.
Thanks! I (finally) figured out a brute force method using the Hurwitz Theorem that works, but Lee's solution is much cleaner.
  • · Replies 17 ·
  • · Replies 0 ·
