How to Calculate Momentum Space Probability for a Particle Initially in a Box?
The discussion revolves around calculating the momentum space probability for a particle initially in the nth eigenstate of a box of length 2a, after the walls of the box are removed. Participants explore the implications of this scenario on energy conservation and the mathematical formulation of the problem.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of the Fourier transform to find the momentum space wave function and the associated probability density. There are questions about the bounds of integration and the necessity of performing the integral to obtain the probability.
Some participants have offered insights into the computations and suggested alternative approaches to simplify the integrals involved. There is an ongoing exploration of the mathematical expressions and transformations needed to evaluate the integrals, with no explicit consensus reached on the final approach.
Participants are navigating the complexities of integrating wave functions and transforming between position and momentum space, with some expressing uncertainty about the integration process and the implications for energy conservation.
Don'tKnowMuch
A particle is initially in the nth eigenstate of a box of length 2a. Suddenly the walls of the box are completely removed. Calculate the probability to find that the particle has momentum between p and p + dp. Is energy conserved?
solution for particle in a box of length L ---->
ψ(x)(sub n) = (2/L)^1/2*sin(n∏x/L)
Fourier Transform of momentum space ----->
ζ(p) = [ 1/(2∏h-bar)^(1/2) ]*∫ e^(-ipx/h-bar)*ψ(x)
I need the probability that the particle is between p & (p+dp). So my plan was to put the ψ(x)(sub n) into the Fourier transform, and then square that to get the probability. My trouble lies in the integral. I am not sure how to compute it. Would the bounds of the integral be p to (p+dp)?
you don't have to do the integral because the P[p+dp,p] = ζ^2(p)dp since ζ^2(p) is the probability density function
This is my understanding, there is a wave function in position space defined for a box of length 2a. This state of definite position is being projected onto a state which has deinfite momentum
ζ(p)^2 = 1/(2∏h-bar) *∫ e^(-ipx/h-bar)^2*( 1/(2a)*sin^2(n∏x/2a))dx
There's still an integral hanging around though. I feel like it needs to be integrated. If that were the case, would i change the sin(stuff) to an exponential and see what comes out?
Hi, in my opinion the computations you have proposed are right. It may be easier to write the exponential as cos+i sin and then use the formulae (from wikipedia :) to compute integrals like sin( ax) cos( bx) or sin( ax) sin( bx) .
Francesco
Looking at the sine term i can simplify the argument a little by setting...
k' = (n∏/2a)
making the sine term------> sin(k'x)
Looking at the exponential, i can say that...
p/h-bar = k
Putting these in the integral looks something like...
ζ(p) = 1/(2∏h-bar)^(1/2)*∫ e^(-ikx)*(1/2i)(e^ik'x-e^-ik'x) dx...
which simplifies to...
ζ(p) = (1/2i)*1/(2∏h-bar)^(1/2)*∫ e^(-ix(k' - k))-(e^-ix(k' + k)) dx...
I have been using every resource at my disposal to crack this one, and to no avail. I saw that the solution to this integral is a combination of delta functions, but i just can't put it together.
