Bilifar Coil Inductor Q&A: What Happens When Powered On/Off?
  • Thread starter Thread starter nemesiswes
    Coil Inductor
The discussion revolves around the behavior of a bifilar coil when powered on and off, specifically focusing on the interactions between two coils (Coil A and Coil B) that are wound in opposition. Participants explore the effects on voltage, inductance, and magnetic fields during the transition from steady state to shutdown and back to power-up.
  • One participant questions what happens to Coil A when Coil B is powered down, suggesting that Coil A may experience a temporary voltage increase due to the opposing voltage induced by Coil B.
  • Another participant raises uncertainty about the effect of Coil A's self-inductance as Coil B's magnetic field decreases, questioning whether this would lower Coil A's voltage and current.
  • There is speculation about the inductance encountered by Coil B when it powers back up, with questions about whether it would behave as if it were a single coil or retain the low inductance due to the opposing field from Coil A.
  • One participant emphasizes the need for clarity in the original question, indicating that the terminology used may lead to confusion.
  • Another participant clarifies the concept of "opposing bifilar coil," explaining that it refers to the arrangement of wire turns that cancel each other's magnetic fields, which is relevant to the inductance behavior discussed.
  • A later reply mentions that bifilar winding is used to maximize coupling between coils and minimize stray fields, adding a technical perspective to the discussion.
Participants express varying levels of understanding and clarity regarding the original question, indicating that there is no consensus on the effects described. Multiple competing views and uncertainties remain regarding the behavior of the coils during the power transitions.
Participants highlight limitations in terminology and clarity, which may affect the understanding of the physical concepts involved. There are unresolved assumptions about the behavior of inductance and magnetic fields in the described scenarios.
nemesiswes
I have a question about a bilifar coil. First I need to set the image,
You have a opposing bilifar coil so as to decrease the inductance of the coil.
http://en.wikipedia.org/wiki/Bifilar_coil
1 Winding will be coil A and the other coil B just so we can all know which coil turn we are all talking about.
Now the question I have is what happens when you power up the bilifar coil to steady state and then shut down, let's say coil B? What happens to coil A?
I believe that Coil A will have a temporary Voltage increase since Coil B would be inducing a voltage opposite it's own voltage.
What effect will Coil A's own inductance have on it's self since as coil B is decreasing , coil A's inductance should be increasing until Coil B is fully off.
Would this inductanc increase somehow lower Coil A's voltage and thus current and thus it's total Magnetic field porduced, it is already at steady state though and no long powering up?
2nd part of the Question is:
What happens to Coil B when it powers back up again, I mean what inductance would it encounter.
Would Coil B's inductance be that of coil B as if it was just a single coil without coil A?
or
Would Coil B's inductance be what is was before when both Coil A and B were powering up, very little because they are opposing each other?
For the 2nd Part or the question, I am not sure what will happen, or the first part for that matter. I think that since Coil A is still on and producing an opposing field to Coil Bs, that coil b's inductance would still be very little and allow it rise to steady state much much faster than if was separate and there was no coil A creating a opposite Magnetic field.
A question well stated is half answered.
I think you need to spend some time formulating your question.
Well I can't think of any simpler way to explain the question, if you read it all the way through it should be pretty straight forward. Then again maybe it is just me that it seems straight forward to and no one else, lol
can you define what you mean by:
"opposing bifilar coil" , i didnt find it on the wiki page
"power up the bilifar coil to steady state "
"and then shut down"
"Coil A's own inductance "
well i need an interpreter !
Maybe somebody else can parse it.
You might print it out and see if it looks same on paper as it does on the screen. I do that a lot to clarify my wording .
old jim
Oh ok, I see where you might get mixed up now, sorry.
I meant that because a bilifar coil is composed of two opposing turns of wire wrapped around the same core, there is one turn that opposes the next turn and so, just like it says on the wiki page for opposing bilifar coils used to create a low inductance coil ( usually wire-wound resistors). Sorry, I can see how that would be confusing, lol, It made it sound like I was talking about two separate bilifar coils.
I mean exactly that, apply power to the bilifar coil, since the coil would have two separate wire turns all on the same core that are wound in such a way that the magnetic field of each is canceled out, You would actually be applying power to two separate coils, just there are both on the same core, you would apply power in one direction for one of them and the opposite direction for the other.
Well there was more to it
"and then shut down, let's say coil B? What happens to coil A? "
I mean pretty much what it says at the end. What happens to coil A if you shut down coil B since they are both on the same core and produce opposing magnetic fields, what happens to coil A when coil B is shut down?
I mean Coil A's self inductance, since Coils b is decreasing in power and so is it's magnetic field, what effect will Coil A's self inductance have on itself. When coil B was on and opposing Coil A's Magnetic field, this caused Coil A's inductance to drop from what it would normally be if it was separate from Coil B, like if you placed them on two different cores and far away from each other so they had no effect on each other.
Sorry for the confusion, lol. I hope this helps to understand what I am trying to ask.
The main reason for a bifilar-wound coil is to maximize the coupling between primary and secondary windings, especially at higher frequencies. I think it also minimizes stray fields.
  • · Replies 20 ·
  • · Replies 17 ·
9K
