Phase-Locking Proton Precession with 90° RF at Lamour Frequency
The application of a 90° radiofrequency (RF) pulse at Lamour frequency in MRI effectively aligns proton spins into phase. This occurs because the RF pulse minimizes the net magnetic moment, balancing the number of protons in parallel and antiparallel alignment with the external magnetic field. As the transverse field rotates with Lamour frequency, protons precess around this field, resulting in all spins reaching the same angle and phase at the conclusion of the pulse. Factors such as finite temperature can affect the uniformity of this phase alignment.
  • Understanding of MRI principles and proton behavior in magnetic fields
  • Knowledge of Lamour frequency and its application in RF pulses
  • Familiarity with the concept of precession in magnetic fields
  • Basic grasp of quantum mechanics as it relates to spin systems
  • Research the mathematical formulation of Lamour frequency in MRI applications
  • Study the effects of temperature on proton alignment and phase coherence
  • Explore advanced MRI techniques involving RF pulse sequences
  • Learn about the impact of magnetic field strength on proton precession
Medical physicists, MRI technicians, and researchers in the field of magnetic resonance imaging who seek to deepen their understanding of proton dynamics and RF pulse applications.
amylase
As title. Thank you.
In the context of MRI, why/how does applying 90 degree radiofrequency at Lamour frequency put proton precessions into phase?
I understand 90 degree RF minimises net magnetic moment, such that there is least difference between number of protons in parallel (with external field) and number of protons in antiparallel alignment (ie. those at higher energy states, and are against external field).
The 90 degree RF also puts proton spins into phase. Why / how does the 90 degree RF wave manage to put protons into phase please?
Thank you.
Let me use the classical picture to illustrate. So think of each spin as a magnetized gyro. Quantum picture ends up working almost exactly the same, but the algebra is a bit more complex.
You have a B field from the main magnet. Most of the proton spins align with that external magnetic field. Now you apply a transverse field that rotates with Lamour frequency. Let's go into a coordinate system that rotates with the applied transverse field. What does the proton experience in that frame of reference? Why, it experiences just the transverse field, which now has a fixed direction perpendicular to the spin. The spin, naturally, begins to precess around that transverse field. The length of the 90° pulse is such that the spins complete exactly 1/4 of revolution around that transverse field.
But now, in the rotating frame, every proton was precessing around the same transverse field with exactly the same phase. So they all ended up at the exactly the same angle, which is perpendicular to both the transverse field and the magnet's constant field at the moment 90° pulse cut out. So all of the spins ended up being in the exact same phase.
Of course, not quite all of the spins started out parallel to the B field, due to finite temperature, so not quite all of the spins will be in phase after 90° pulse either. This is one of many factors responsible for finite peak widths.
  • · Replies 16 ·
  • · Replies 24 ·
13K
