Max Ramp Angle for Rolling Ball: mu & Theta
The discussion revolves around the maximum angle of a ramp (theta) for a rolling ball with a coefficient of static friction (mu) and the dynamics of two balls, one filled with fluid and the other solid, rolling down the ramp. Participants explore the implications of these factors on motion, acceleration, and energy considerations.
  • Carla proposes that the maximum angle theta for rolling without slipping is given by theta max = inverse(tan(mu)), but notes a discrepancy with a book answer of theta = inverse(tan(3.5mu)) and seeks clarification on the origin of the factor 3.5.
  • Carla questions whether two balls, one fluid-filled and one solid, would reach the bottom of the ramp at the same time, suggesting that mass cancels out in the acceleration equation.
  • One participant questions if the fluid-filled ball weighs more, suggesting that the lighter ball might reach the ground first due to alternating between rolling and freefalling.
  • Another participant asserts that the fluid-filled ball would roll slightly slower due to friction and viscosity, prompting a request for a formulaic demonstration of this claim.
  • A participant introduces a hypothetical scenario involving an object with low friction inside the ball, discussing how internal energy changes might affect kinetic energy during rolling.
  • One participant dismisses a previous comment about air friction, emphasizing that internal friction from the fluid is relevant to the discussion.
Participants express differing views on the dynamics of the rolling balls and the implications of fluid dynamics on motion. There is no consensus on the maximum angle or the effects of fluid on rolling behavior, indicating ongoing debate and exploration of the topic.
Participants reference various assumptions about mass, friction, and energy without resolving the underlying mathematical relationships or providing definitive formulas. The discussion remains open to interpretation and further exploration.
rhuala
Ball mass m and radius r rolls down ramp with coefficient of static friction of mu. If the ball is released from rest what is the maximum angle theta of the ramp that the ball rolls without slipping?
I've got theta max = inverse(tan(mu)) but the answer in the book is
I'm not sure where the 3.5 comes in could someone please explain?
Also if 2 balls roll down a ramp, one is filled with fluid the other not which one reaches the bottom first. The mass cancels out the the equation for the acceleration so it seems to me they should reach the bottom at the same time. Just wanted to verify that this is correct.
Thanks in advance
Carla
"Also if 2 balls roll down a ramp, one is filled with fluid the other not which one reaches the bottom first. "
Does the fluid-filled one weigh more?
It seems to me that the lighter ball would reach the ground first.
1] The lighter ball will alternate between rolling and freefalling (after each little bump)
2] The The heavier ball also resists the turning caused by friction, thus will accelerate slower.
Perhaps you are confusing this problem with finding the maximum angle that an incline can be increased before an object begins sliding down?
Hint: There is a net force acting down the incline---apply Newton's 2nd law for both translation and rotation.
Friction and viscosity of the fluid should cause the fluid filled ball to roll slightly slower.
Can you (or someone) show this through formula please, I'm not sure this is correct...
I don't know the formula's for this, but here's an similar example.
Replace the fluid with an object of a certain mass with a low coefficient of friction. As the ball rolls, the object is raised a bit, and then starts sliding inside of the ball as the ball rolls. In addition to increasing the kinetic engergy of the ball, temperature energy is also being increased (from the friction).
Since the initial potential engery is the same for both balls at the start, the ball with the increasing temperature energy ends up with less of an increase in kinetic energy.
ignore what jeff said... air friction play no role in this problem
identify the problem and read #3 post carefully... let me know how far you get or where you stuck b4 i can further help you... this problem is not as hard as you think... and don't expect it is a easy problem... (am i contradicting myself?) :wink:
I never mentioned air friction. One of the questions concerened fluid in a ball, which is a source of internal friction (viscosity).
  • · Replies 32 ·
  • · Replies 60 ·
12K
