What is the difference between relative velocity and resultant velocity?
The discussion clarifies the distinction between relative velocity and resultant velocity. Relative velocity is defined as the velocity of one object as observed from another object's frame of reference, while resultant velocity is the combined effect of multiple velocity vectors acting on an object. An example provided involves a plane's velocity relative to the wind and the ground, illustrating how to calculate resultant velocity by vector addition. Additionally, methods for calculating acceleration and velocities in a connected pulley system are discussed, emphasizing the importance of differentiating heights and solving simultaneous equations.
  • Understanding of vector addition in physics
  • Familiarity with basic kinematics concepts
  • Knowledge of differentiation and its application in motion analysis
  • Experience with solving simultaneous equations
  • Study vector addition in physics, focusing on velocity components
  • Learn about kinematic equations for motion analysis
  • Explore differentiation techniques in the context of physics
  • Investigate methods for solving simultaneous equations in mechanics
Students of physics, educators teaching mechanics, and engineers working with motion analysis will benefit from this discussion.
suryanarayan
relative velocity and resultant velocity?also in a connected(with strings) pulley system,how can we calculate the acceleration and velocities of the pullies and the masses connected onto it?
hi suryanarayan! :smile:
resultant velocity is an alternative (and in my opinion less satisfactory) name for relative velocity
eg if the velocity of the wind is u, and the velocity of the plane relative to the wind is v,
then the velocity of the plane relative to the ground is u + v, which is sometimes called the resultant velocity since it is the resultant of the two vectors :wink:
if there's only one string, call the height of one of the pulleys "a", and see what happens to the heights of the other items
then differentiate once for speed, and twice for acceleration :wink:
(if there's n strings, you need to start with the heights of n items, and solve the simultaneous equations)
Loosely, I'd say that relative velocity refers to how one observer in his own frame would see another moving object. Resultant velocity would be the velocity of an object (in some fixed reference frame) when there are more than one influences on its motion. OR, what you get when you start off by Resolving the motion of an object into two arbitrary directions (e..g. vertical and horizontal) to make your calculations easier. You then you add the two vectors together to get the overall resultant velocity.
The word 'resultant' is used for the sum of many vectors in general (forces, acceleration. magnetic field etc.)
  • · Replies 18 ·
  • · Replies 20 ·
  • · Replies 30 ·
