Car Fuel Problem, calorific values.
  • Thread starter Thread starter Miller11
    Car Fuel
The discussion centers on calculating the output power of an engine using a fuel mix of 90% Nitromethane (CH3NO2) and 10% Octane (C8H18). The calorific values are 11.3 MJ/kg for Nitromethane and 43.7 MJ/kg for Octane. The user, Miller11, initially calculates the mol/sec for a pure Octane engine producing 100 kW, assuming the same volumetric efficiency for the fuel mix. However, they encounter difficulties in determining the power output for the fuel mix, which should theoretically yield higher power due to the oxygen content in Nitromethane. A suggestion is made to balance the chemical equations for both fuels to accurately assess the combustion process.
  • Understanding of calorific values and their implications in fuel energy calculations
  • Familiarity with the chemical equations for combustion of hydrocarbons
  • Knowledge of molar mass calculations and their application in thermodynamics
  • Basic principles of engine efficiency and power output calculations
  • Learn how to balance chemical equations for hydrocarbon combustion
  • Research the impact of oxygen content in fuels on combustion efficiency
  • Explore the thermodynamic properties of Nitromethane and Octane
  • Investigate advanced engine performance modeling techniques
Engineers, automotive performance specialists, and students in thermodynamics or combustion science who are interested in optimizing engine power output using alternative fuel mixtures.
Miller11
1) I need to find the output power in kW of an engine when running a mix of 90% Nitromethane
(CH3NO2), and 10% Octane (C8H18), their calorific values are 11.3 MJ/kg and 43.7 MJ/kg respectively.
what i know:
An engine that runs pure 100% octane with 20% excess air produces 100kW, and the volumetric, thermal and mechanical efficiency's remain the same.
I need to find out how much power the same engine using a 10/90 fuel mix would produce.2)Im using this equation:
Power (kW)=Power (kJ/sec)= [calorific value fuel(kJ/kg)] X [molar mass of fuel(kg/mol)] X
[mol/sec]
Im assuming since the volumetric efficeincy will be the same then the [mol/sec] i get for the first engine will be the same as the second fuel mix.
100kW = [(43.7 x 10^3)kJ/kg] X [(114.224)kg/mol] X mol/sec
hence,
mol/sec for both engines = 0.02.
But I am stuck from there and don't know how to continue, as when i try subbing this value into the same equation with the second fuels mix, i get a lower power which it shouldn't be.
Any help would be greatly appreciated.
Cheers Miller11
Is this problem from a thermodynamics course?
To work this problem you will have to write the chemical equations for each fuel, balance them both, and determine how much fuel is being burned given the 20% excess air. In doing so you will find that you can burn more nitromethane fuel and therefore produce more power because nitromethane contains oxygen.
9K
  • · Replies 23 ·
  • · Replies 47 ·
9K
9K
14K
