Thermal properties of ice cream
The discussion focuses on the thermal properties of ice cream, specifically thermal conductivity and latent heat, and how these properties vary with temperature. Participants explore both conceptual and practical aspects related to these properties in the context of a mechanical engineering project.
  • Homework-related
  • One participant requests information on the thermal properties of ice cream, including thermal conductivity and latent heat, and their variation with temperature.
  • Another participant provides specific values for the thermal properties of ice cream at constant temperatures, including latent heat of fusion, density, and specific heat at different temperatures.
  • A different participant suggests that the enthalpy of fusion is relatively temperature-independent for engineering purposes, and discusses the importance of considering the overrun (air content) in ice cream when estimating density.
  • Further, they propose a method for calculating the density of a two-phase mix (ice cream and air) using a volume fraction-weighted average based on known densities and the ideal gas law.
  • One participant expresses gratitude for the information and seeks additional suggestions for substances to analyze in their ongoing research for a Master's project, mentioning plans to use ANSYS FLUENT for computational analysis.
  • Another participant offers to share articles related to the topic, indicating they have relevant resources available.
Participants do not reach a consensus on the variation of thermal properties with temperature, and multiple viewpoints regarding the estimation methods and relevance of certain properties remain present.
The discussion includes assumptions about the air content in ice cream and the approximation methods for density, which may depend on specific conditions and definitions not fully explored in the thread.
sonu_123
i need some conceptual help for my final year project...
what are the thermal properties of ice cream?? Specifically the thermal conductivity and latent heat and the relation of it's variation with temperature...
i'll be adding a copy of my abstract for better understanding. oh and yeah I'm a mechanical engineer by the way...
I'm really sorry but that doesn't help me much as I've already made use of GOOGLE search and GOOGLE SCHOLAR for the values. What I have in my hand are the thermal properties at a constant temperature. I need a relation that tells me how those properties vary with temperature.
S. No Name of the Constant Value
1. Latent Heat of Fusion of Ice Cream 210.14 J/kg
2. Density 568 kg/m3
3. Specific Heat of Ice Cream at 4°C 2.948 J/kg-K
4. Specific Heat of Ice Cream at -26°C 1.629 J/kg-K
5. Thermal Conductivity of Ice Cream at 4°C .694 W/m-K
6. Thermal Conductivity of Ice Cream at -26°C .993 W/m-K
Assuming you're after fairly rough-and-ready engineering values, I'll try offering some comments:
1. The enthalpy of fusion is a rather weak function of temperature. For most engineering purposes, assuming it's temperature independent is not a bad approximation.
For the rest of the comments below, I have to assume you know how much overrun (that is, included air) you have. Commonly ice cream runs about 25-30% air by volume. I hope you won't say there isn't any, because if you did, your "ice cream" would be more like a solid block of flavorful ice.
Anyhow:
2. Density of a two phase mix, which is essentially what you have here, is often estimated as a volume fraction weighted average of the components. Thus, if you know your ice cream is (let's say) 25% by volume air, you can get the air density at atmospheric pressure and the desired temperature by the ideal gas law. The "liquid" part of it-that is, the actual freeze mix of milk, flavoring, sweetener, and whatnot-could be reasonably approximated by the density of milk, tables/correlations for which are likely available from agricultural extension services, among other places. Put those data together in a volume fraction-weighted average for various temperatures and there you have your density as a function of temperature.
I'll follow with more comments later. Gotta go right now.
Well...That data was very helpful...
I have completed my Under-Grad Project but need even more help as I am working on the same thing for my Masters. Suggestions on what other substances can be used for the analysis would be very helpful too.
I am planning to perform the computational analysis using ANSYS FLUENT this time as I have worked on ANSYS APDL Mechanical the previous time. So help/tutorials regarding the same would also be appreciated.
Apologies. Didn't see this thread until today and didn't see the date, either.
Anyhow: I know of two articles published about 9 years ago that address these topics pretty well. Send me a PM with your e-mail and I can provide PDFs of these articles if you're interested.
  • · Replies 26 ·
  • · Replies 24 ·
  • · Replies 16 ·
15K
