Magnitude and Direction of a Magnetic Field at the Circumference of a Disk
The discussion focuses on calculating the magnitude and direction of the magnetic field at the circumference of a non-conducting disk with an initial charge of QO = +5 μC that decreases over time according to the equation Q(t) = QO e-t/τ, where τ = 10 seconds. The relevant equations include ∇·E = (1/εO)ρ and ∇×B = μOJ + μOεO (∂E/∂t). The challenge lies in applying these equations correctly to determine the magnetic field's behavior as a function of time, particularly at the disk's edge.
  • Understanding of electromagnetic theory, specifically Maxwell's equations.
  • Familiarity with the concepts of electric displacement field (D) and magnetic field (B).
  • Knowledge of the behavior of electric charges over time and their impact on magnetic fields.
  • Ability to perform vector calculus operations, particularly curl and divergence.
  • Study the application of Maxwell's equations in time-varying fields.
  • Learn about the relationship between electric fields and magnetic fields in non-conducting materials.
  • Investigate the effects of charge decay on magnetic field generation.
  • Explore advanced topics in electromagnetic theory, such as electromagnetic waves and their propagation.
Students and professionals in physics, particularly those focusing on electromagnetism, electrical engineers, and anyone involved in theoretical physics or electrical field analysis.
GermanMC
A very thin disk of non-conducting material initially holds a charge QO = +5 μC that decreases with time t as
Q(t) = QO e-t/τ
If the disk has a radius of 0.10 m, what is the magnitude and direction of the magnetic field at the circumference of the disk as a function of time?
Assume at any time t that the displacement vector D is uniform across the disk.
There is no free current.
∇[itex]\bullet[/itex]E = (1/εO
I tried to just work out the curl of B and I immediately ran into problems and it's not correlating to the problem.
Show your work. Don't just describe what you did generally.
