What happens to a sphere's velocity in freefall when elevator cables break?
The discussion revolves around the behavior of a sphere's velocity when it is inside an elevator that begins to freefall after its cables break. Participants explore the implications of terminal velocity, buoyant forces, and viscous forces in this scenario, considering both ideal and non-ideal conditions.
  • One participant notes that terminal velocity is achieved when air resistance equals gravitational force, suggesting that the motion of the sphere will be complicated when the elevator starts moving.
  • Another participant claims that the terminal velocity with respect to an inertial frame would increase in the freefalling elevator compared to a stationary or slowly moving upward elevator, while remaining the same with respect to the air inside the elevator.
  • A different viewpoint suggests that as gravitational force drops to zero, buoyant force would also reduce to zero, leading to a decrease in the sphere's velocity and potentially pushing it against the elevator's roof.
  • One participant argues that buoyant force is negligible for small objects and that the sphere's velocity relative to the elevator would eventually go to zero, but it would not be pushed against the roof.
  • Another participant counters that the sphere's behavior depends on whether it is neutrally buoyant and that if both the sphere and the elevator are in free fall, the sphere would maintain the same velocity as the elevator in a vacuum, but would fall faster due to less drag in air.
Participants express differing views on the effects of buoyant and viscous forces, as well as the implications of freefall on the sphere's velocity. There is no consensus on the final behavior of the sphere in relation to the elevator.
Some assumptions regarding the conditions of the elevator and the sphere's properties remain unresolved, such as the effects of air resistance and the specific initial conditions of the system.
Binayak95
A sphere inside an elevator is falling at terminal velocity. Say the elevator cables break and it starts to freefall, what happens to the sphere's velocity?
I have developed some rudimentary solution but would like to see a confirmation.
Terminal velocity is due to air resistance equal to the gravitational force. When the elevator starts moving, the air in the elevator will be jostled along with the elevator car, and the sphere will be jostled along with the air. The exact motion will be messy and far from an ideal situation that you usually see in gedanken experiments.
The terminal velocity with respect to an inertial frame would increase in the freefalling elevator compared to a stationary one or one that is moving upward slowly.
It will remain the same with respect to the air in the elevator.
Interesting problem. I'm too dumb to answer.
I thought that since g would drop to zero buoyant force would also reduce to zero. Since Viscous force would still exist, the sphere's velocity would reduce and eventually the sphere would be pushed against the elevator's roof.
The buoyant force in air is essentially negligible except for very large, light objects like zeppelins. Compared to other forces at work, it is almost always very small.
Now, since your elevator is moving down, the air inside is moving down with the same speed with regard to an inertial frame (say, the elevator shaft). Viscous forces depend on the speed of the object with respect to the fluid it is traveling through, so if you had one ball falling inside the elevator and one ball falling outside of it through the shaft with the same initial speed (with respect to the shaft), the ball outside the elevator would be moving with a greater speed with respect to the fluid it is moving through than the one inside the elevator, so viscous forces would be greater on the ball in the shaft rather than the ball in the elevator.
No, that's wrong. After some time (long elevator shaft), the sphere's velocity will go to zero relative to the elevator, but it won't be pushed against the root.
That is also not true unless the ball was neutrally buoyant in the elevator or the elevator is also in free fall. If the elevator was also in free fall and the ball was released at the same time, the ball would remain at the same velocity as the elevator if it was a vacuum, but because of air, the ball will still fall faster since it will have less drag on it than the elevator and so will accelerate more.
  • · Replies 22 ·
  • · Replies 28 ·
11K
  • · Replies 47 ·
