Use the density of the liquid to estimate the radius of a neon atom.
The discussion focuses on calculating various properties of neon, including its volume at standard conditions, atomic weight, RMS speed, and estimating the atomic radius using the density of liquid neon. The volume occupied by one mole of neon at 273 K and 1 atm is calculated to be 0.0224 m3. The atomic weight of neon is determined to be 10 g/mol, and the RMS speed is calculated as 824.98 m/s. The estimated radius of a neon atom, derived from the liquid density, is calculated to be 49.42 m, which is recognized as an unrealistic value for atomic dimensions.
  • Ideal Gas Law (PV = nRT)
  • Concept of RMS speed in kinetic theory
  • Understanding of atomic weight and molar mass
  • Basic principles of density and volume calculations
  • Study the Ideal Gas Law and its applications in thermodynamics
  • Learn about kinetic theory and the derivation of RMS speed
  • Explore atomic structure and the significance of atomic radius
  • Investigate the properties of noble gases and their behavior under various conditions
This discussion is beneficial for chemistry students, educators, and anyone interested in the physical properties of gases and atomic theory, particularly in relation to noble gases like neon.
EmmaLemming
Neon is a monatomic gas;
Density = 0.900 kg.m-3
Pressure = 1 atm
Temperature = 273K.
Density of liquid neon = 1207 kg.m-3
(i) Calculate the volume occupied by one gram mole of neon at a temperature of 273 K and a pressure of 1 atm.
(ii) Determine the atomic weight of neon.
(iii) Calculate the RMS speed of a neon atom at 273 K.
(iv) Use the density of the liquid to estimate the radius of a neon atom.
2. The attempt at a solution
i) V = nRT/P = 0.0224m3
ii) n= m/M ∴ m = nM = 1x10 = 10g = 0.01kg
iii) VRMS = √(3RT/M) = 824.98ms-1
iv) third-root(liquid density/mass) = 49.42m <-- Bit big for an atom :s
I am stuck on part iv) however I may have made a mistake further up so I have included the whole question and my working. Please help.
A mole of neon occupies the volume you calculated.
How many atoms of neon can one find in 1000 liters/1cubic meter of liquid neon ?
12K
19K
