New Reply
conservation of angular momentum and change in rotational kinetic energy
Share Thread Thread Tools
May3-12, 11:21 PM   #1
I have a question regarding angular momentum and rot kinetic energy. For example, if angular momentum is conserved, and the radius is cut in half, then moment of inertia is reduced by a fourth, which will result in increase in angular velocity by factor of 4. My question is why is the rotational kinetic energy increase by a factor of 4 also. Since the equation of rot kinetic energy is (1/2)Iw^2, the new w increased by factor of 4 but the new I also decreased by factor of 1/4. So wouldn't KE stay the same???
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
May4-12, 03:56 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
hi chamddol! welcome to pf!
Quote by chamddol View Post
… if angular momentum is conserved, and the radius is cut in half, then moment of inertia is reduced by a fourth, … why is the rotational kinetic energy increase by a factor of 4 also … wouldn't KE stay the same???
as you know, angular momentum is always conserved (if there's no external torque, of course)
in a "collision" situation, (mechanical) energy usually isn't conserved, but if the changes are gradual (as here), yes we would usually expect it to be conserved
however, that's forgetting the work energy theorem … work done = change in mechanical energy
imagine that you're rotating on ice, and you're holding onto a heavy mass on a rope
if you pull the rope in, the total energy increases because you are doing work (force "dot" distance) by pulling the mass in
when you reduce the moment of inertia of any rotating mass, you have to do work!
May4-12, 08:00 AM   #3
Recognitions:
Er - no. Think that through again. You've reduced I by a factor of 4, and increased w by a factor of 4, so you've increased w^2 by a factor of ...?
May4-12, 03:52 PM   #4
Recognitions:
I have a question regarding angular momentum and rot kinetic energy. [...] radius is cut in half, [...] will result in increase in angular velocity by factor of 4. My question is why is the rotational kinetic energy increase by a factor of 4 also.
Expanding on the answer given by tiny-tim:
The curved line in the diagram represents the trajectory of an object that is pulled closer to the center. The dark grey arrow represents the centripetal force.
Now, in the case of perfectly circular motion the centripetal force is at all times perpendicular to the instantaneous velocity, and hence there is no change of kinetic energy. But here, with the object being pulled closer to the center, the exerted force is not perpendicular to the instantaneous velocity.
You can think of the force as decomposed, one component perpendicular to the instantaneous velocity and one paralllel to the instantaneous velocity. The perpendicular component causes change of direction, the parallel component causes acceleration.
So in the process of pulling closer to the center you are doing work upon the object. This is big: by the time you've managed to reduce the radial distance by half you have quadrupled the kinetic energy.
In general: when you have an object in circumnavigating motion, and you pull that object closer to the center, then the acceleration occurs because you are doing work upon that object.
May5-12, 12:31 AM   #5
Rap
haruspex is right. Its a simple mathematical error.
New Reply
Tags
angular momentum
Thread Tools
Similar Threads for: conservation of angular momentum and change in rotational kinetic energy
Thread Forum Replies
Problem on Rotational mechanics / Conservation of angular momentum. Introductory Physics Homework 1
conservation of angular momentum / finding change in rotational kinetic energy Introductory Physics Homework 11
Is the Change in Rotational Kinetic Energy Frame Invariant? Classical Physics 6
Finding the change in Rotational Kinetic Energy Introductory Physics Homework 7
Change in total kinetic energy in a conservation of momentum problem? Introductory Physics Homework 9
