Two State Quantum System with a given Hamiltonian
The discussion centers on a two-state quantum system characterized by the Hamiltonian H=E (0 1; 1 0). The initial state is given as ψ(0)=(0; 1). The participants analyze the time evolution of the state, Ψ(t), using the time-dependent Schrödinger equation, leading to the conclusion that the probability of observing the ground state energy at time T is 100%. Additionally, the probability of the system being in the state (1; 0) at time T is calculated to be 0, based on the inner product of the states.
  • Understanding of quantum mechanics principles, particularly the time-dependent Schrödinger equation.
  • Familiarity with Hamiltonian operators and their role in quantum systems.
  • Knowledge of matrix exponentiation in the context of quantum state evolution.
  • Ability to compute inner products of quantum states to determine probabilities.
  • Study the time-dependent Schrödinger equation in detail, focusing on its applications to two-state systems.
  • Learn about Hamiltonian mechanics and how to derive probabilities from quantum states.
  • Explore matrix exponentiation techniques relevant to quantum mechanics.
  • Investigate the implications of degenerate energy levels in quantum systems.
Students and professionals in quantum mechanics, physicists working with quantum systems, and anyone interested in the mathematical foundations of quantum state evolution.
bgrape
A two state system has the following hamiltonian
[tex] <br /> H=E \left( \begin{array}{cc} 0 & 1 \\<br /> 1 & 0 \end{array} \right)<br /> <br /> [/tex]
The state at t = 0 is given to be
[tex] <br /> \psi(0)=\left( \begin{array}{cc} 0 \\ 1 \end{array} \right)<br /> <br /> [/tex]
• Find Ψ(t).
• What is the probability to observe the ground state energy at t = T ?
• What is the probability that the state is
[tex] <br /> \left( \begin{array}{cc} 1 \\ 0 <br /> \end{array} \right)<br /> <br /> [/tex]
at t = T ?
[tex] i\hbar\frac{\partial\psi}{\partial t} = \frac{\hbar^2}{2m}\nabla^2\psi + V(\mathbf{r})\psi[/tex]
My main problem is with the notation. I understand that this system has two states with the same energies. I think this system can be an electron in an energy level, it has up or down spin possibilities. I think since both the states have the same energy both are considered ground state therefore we have 100% possibility to observe the ground state energy at t=T and the probability that the state is [tex] <br /> \left( \begin{array}{cc} 1 \\ 0 <br /> \end{array} \right)<br /> <br /> [/tex] at t=T seems to be 1/2 intuitively because there is no energy difference between the states. However I don't know the correct notation for Ψ(t). I am thinking of
[tex] \psi(t)=\left( \begin{array}{cc} e^{(-iEt/\hbar)} \\<br /> e^{(-iEt/\hbar)} \end{array} \right)[/tex]
but this does not define that the system is in the particular state at t=0. Any help is greatly appriciated.
Note that [tex]\psi(0)[/tex] is not an eigenstate. So you need to solve the time dependent Schrödinger equation. The wave function at time t is given by:
[tex]\psi (t)=\exp({-i/\hbar Ht})\psi (0)[/tex]
You need to calculate the matrix exponential function!
Thanks for your reply csopi. I have corrected my Ψ(t) as below, what I though of first was a fatal mistake.
[tex] \psi(t)=e^{(-iEt/\hbar)}\left( \begin{array}{cc} 0 \\<br /> 1 \end{array} \right)[/tex]
Is my assumption that since both energies are the same both can be considered as ground state and probability to observe the state at t=T will always be 1 correct?
for the next part
[tex]\left( \begin{array}{cc} 1 \\ 0 <br /> \end{array} \right)[/tex]
at t = T ?
I think i will have to evaluate
[tex]| \langle \phi | \psi \rangle |^2[/tex]
and i think [tex]\phi = \left( \begin{array}{cc} 1 \\ 0 <br /> \end{array} \right)[/tex]
and
[tex]| \langle \phi | \psi \rangle |^2 = (\left( \begin{array}{cc} 1 & 0 <br /> \end{array} \right)\left( \begin{array}{cc} 0 \\<br /> 1 \end{array} \right)e^{(-iET/\hbar)})^2 =0[/tex]
Am I on the right track? I am not sure on how to calculate the probability of a state and an energy at a specific time, any help or tip is more than welcome.
