How Does Trailer Weight Impact the Work Done by a Car?
The discussion revolves around the impact of trailer weight on the work done by a car pulling it. The original poster presents a scenario involving a car pulling a trailer of a specified weight and force over a distance, questioning how the weight influences the work done.
  • The original poster attempts to calculate work done using the formula for work but expresses confusion about the relationship between trailer weight and work done. Some participants explore the concept of energy change and its relation to mass and speed, while others question the assumptions regarding the force applied and its effects.
The discussion is active, with participants engaging in clarifying concepts related to work and energy. There are multiple interpretations being explored regarding the effects of weight on work done and energy changes, but no explicit consensus has been reached.
Participants are navigating assumptions about the relationship between force, weight, and work done, as well as the implications of kinetic energy in the context of the problem. There is a noted request for simpler explanations due to varying levels of understanding among participants.
influx
EDIT: I JUST REALISED YOU CAN'T DO 1 WORD THREAD TITLES, SORRY ! WON'T DO IT AGAIN!
A car pulls a trailer of weight 2500 N with a force of 20 N for a distance of 8 km along
a horizontal road.
How much work is done by the car in pulling the trailer?
A 160 J
B 20 000 J
C 160 000 J
D 20 000 000 J
I know work done = force x displacement
so it should be 20 x 8000 = 160,000 J (so the answer is C)
But what I am confused about is surely the weight of the trailer will affect how much work the car does in pulling it? I mean for instance if the trailer was 5 N, shouldn't the work done be MUCH less .. BTW can you please try explain in simple terms since I am not that advanced at Physics as you guys.
Cheers :)
hi influx! :smile:
a horizontal road.
… surely the weight of the trailer will affect how much work the car does in pulling it? I mean for instance if the trailer was 5 N, shouldn't the work done be MUCH less
work done = change in energy
if you applied the same force for the same distance, the two trailers' increased kinetic energy would be the same
but the heavier trailer's speed would have increased less :wink:
tiny-tim said:
Hi :)
Oh! Never knew that! When you say change in energy, what exactly do you mean? And does the speed increase less because kinetic energy = 1/2(mv2) , so as the value for 'm' increases, the value of 'v' decreases?
Cheers
if the speed goes from u to v, then the change in energy (on a horizontal road) is 1/2mv2 - 1/2mu2
if that is the same for two masses, the one with larger m must have smaller (v2 - u2)
Who says that the 20N force is increasing the KE of the trailer, and not just overcoming air resistance?
17K
16K
  • · Replies 52 ·
