Quotient groups of permutations
The discussion revolves around the concept of quotient groups, specifically focusing on the quotient group S4/L, where L is a normal subgroup of S4. Participants explore the challenges of identifying the elements of the quotient group and the implications of Lagrange's theorem on its order.
  • One participant expresses understanding of quotient groups with smaller groups like D8 but struggles with larger groups such as S4.
  • Another participant proposes that the order of the quotient group S4/L is 6, based on Lagrange's theorem, and discusses the non-abelian nature of the group.
  • Concerns are raised about the difficulty of finding all elements of S4/L without calculating all cosets, suggesting that this could lead to a large number of duplicates.
  • One participant speculates that the quotient group might be isomorphic to D6.
  • A later reply indicates a method for finding cosets more efficiently, starting with specific elements and demonstrating how to derive additional cosets from them.
  • Another participant clarifies that checking specific products can lead to conclusions about the non-abelian nature of the group without exhaustive calculations.
  • It is mentioned that the quotient group is isomorphic to D6, also referred to as S3, and clarifies the notation used for dihedral groups.
Participants express varying levels of understanding and approaches to finding the elements of the quotient group. While some agree on the order and structure of the group, others raise questions about the methods used to derive the cosets, indicating that the discussion remains unresolved regarding the most efficient approach.
Participants acknowledge the complexity of identifying cosets in larger groups and the potential for duplicates among them. There are also discussions about the implications of normal subgroups and the properties of the resulting quotient group.
Jesssa
hey guys,
I just want grasp the whole concept of quotient groups,
I understand say, D8/K where K={1,a2}
I can see the quotient group pretty clearly without much trouble however I start to get stuck when working with larger groups, say S4
For instance S4/L where L is the set of (xx)(xx) elements of S4 including e,
Without going through and doing all the calculations I know that the order of the quotient group will be 6, however I can't see what the group will be,
L is a normal subgroup of S4 since each element in L contains its conjugate so left and right cosets equal.
I first thought the quotient group would be something like
{1,(xx)L,(xx)(xx)L,(xxx)L,(xxxx)L,?} (different length cycles x L) but there are only 5 different length cycles.
Is there a way to find these quotient groups without having to multiply L but every element of S4?
Jesssa said:
hey guys,
We can try the following approach: in the quotient group [itex]\,\,S_4/L\,\,[/itex] , with [itex]L:=\{(1),\, (12)(34),\, (13)(24),\, (14)(23)\}\,\,[/itex] , we have
that [itex]\,\,(12)L\neq (123)L\,\,[/itex] , since [itex]\,\,(12)(123)^{-1}=(12)(132)=(13)\notin L[/itex] .
Thus, by Lagrange's theorem the group [itex]\,\,S_4/L\,\,[/itex] has order 6 and by the above it isn't abelian, thus it is isomorphic with...
DonAntonio
Sorry I don't follow,
Doesn't having (12)L ≠ (123)L just mean there two elements of S4/L and the rest shows (13)L≠L, but (13)L could equal (some other permuation in S4)L,
Is there no way to find all the elements of S4/L without doing gL for all gεS4 and finding which ones are equal, that would give 24 cosets and 18 of the cosets would have to be duplicates of the remaining 6 to give an order 6 group right?
I could give a guess, is it isomorphic to D6?
I was just kind of hoping there was a fast way to find quotient groups, without, in this case, having to multiply L by 24 permutations and find which of these cosets are equal
edit
oh i think i worked it out,
start with (12)L
then you get {(12),(34),( 1 4 2 3 ),( 1 3 2 4 )}(12)(13)(24) = (1423), so (13)(24)=(12)(1423) then (13)(24)(1423)=(12)
so (13)(24)(1324) = (12)
and its a normal subgroup so left and right cosets are equal so (12)L = (1324)L
similar argument you can get (12)L=(1423)L=(34)L
so you find 4 cosets in one, so you'll only have to do 6 calculations to find the quotient group
edit
start with (12)L
Ok, perhaps I wasn't clear enough. What I thought is that you'd check the elements [itex]\,\,(12)(123)L\,\,,\,\,(123)(12)L\,\,[/itex] and reached the
(correct, even) conclusion that they're different, thus making the quotient a non-abelian group without checking all the different 24 products, or even close.
And yes, the quotient is isomorphic with [itex]\,\,D_6\cong S_3\,\,[/itex] , though (the most common notation is the second one), and the
more usual name for the dihedral group of order 2n is [itex]\,\,D_n\,\,,\,\,not\,\,D_{2n}[/itex]
DonAntonio
  • · Replies 17 ·
