Register to reply
Add vectors
by Philosophaie
Tags: vectors
Share this thread:
Philosophaie
#1
May5-12, 04:31 AM
P: 368
How do you add two vectors:
(r1, theta1, phi1) + (r2, theta2, phi2)
I know if you break them down into x, y, z components you get the right answer but how do you add these vectors.
Phys.Org News Partner Mathematics news on Phys.org
Heat distributions help researchers to understand curved space
Professor quantifies how 'one thing leads to another'
Team announces construction of a formal computer-verified proof of the Kepler conjecture
Erland
#2
May5-12, 06:31 AM
P: 345
As you said, transform them to rectangular coordinates (xyz-components), add them, and then transform back to spherical coordinates.
HallsofIvy
#3
May5-12, 06:53 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,556
If you mean "without using components" (i.e. the hard way) you use trigonometry.
Draw a line segment with one end at (0, 0, 0) in the direction given by theta1 and phi1 with length r1. At its tip, draw a second line segment in the direction given by theta2 and phi2 with length r2. Finally, draw the line segment from (0, 0, 0) to the tip of the second line segment. This forms a triangle in which you know the length of two sides and the angle between them so can use the sine and cosine laws to determine the length and angles of the third side. It is determining the angle between the two sides that is complicated.
Register to reply
Related Discussions
Unit tangent vectors, Normal vectors, and Gradients Calculus & Beyond Homework 0
Linear Algebra - Use angles between vectors to find other vectors Calculus & Beyond Homework 4
Find unknown constant of two vectors to make vectors perpendicular to each other? Calculus & Beyond Homework 8
Vectors: Given two vectors, find a vector that bisects the angle between the two give Calculus & Beyond Homework 10
Position Vectors, Velocity Vectors, and Acceleration Vectors Introductory Physics Homework 3
