Reversible adiabatic expansion using Van der Waals' equation
The discussion revolves around the application of Van der Waals' equation for a real gas during a reversible adiabatic expansion. Participants are tasked with deriving a relationship between pressure and volume, while also determining the parameter \(\gamma\) in terms of molar heat capacity \(C_v\) and the gas constant \(R\).
  • Participants explore the derivation of the relationship \((p + A/V^2)(V-B)^\gamma = \text{const.}\) and question the appearance of the gas constant \(R\) in their calculations. They discuss integrating the equations and the implications of constants in the context of the problem.
Some participants have provided insights into the role of the gas constant \(R\) and its relevance in the context of Van der Waals' equation. There are ongoing attempts to clarify the steps leading to the inclusion of \(R\) in the derived expressions, with no explicit consensus reached yet.
Participants are working under the constraints of a homework assignment, which may limit the information available and the methods they can employ. The discussion reflects uncertainty regarding the derivation steps and the definitions involved in the equations.
Kweh-chan
A real gas obeys Van der Waals‟ equation, which for one mole of gas is
(p + A/V2)(V-B) = RT
and its internal energy is given by
U = CvT - A/V
where the molar heat capacity at constant volume, Cv , is independent of the
temperature and pressure. Show that the relation between the pressure p and
the volume V of the Van der Waals‟ gas during a reversible adiabatic
expansion can be written as
(p + A/V2)(V-B)[itex]\gamma[/itex] = const.
and find the expression for the parameter [itex]\gamma[/itex] in terms of Cv and R .
U = CvT - A/V
Q= U + W
There is already a given solution and method for this equation. I worked through this much:
0 = U + W
0 = dU + PdV
dU = (dU/dT)dT - (dU/dV)dV = CvdT + (A/V2)dV
0 = CvdT + (P + A/V2)dV = CvdT + RT/(V-B)
∫R/(V-B) dV = -∫Cv(dT/T)
Rln(V-B) + Cvln(T) = const.
ln(V-B)R + ln(T)CV = const
ln[(V-B)R(T)CV] = const.
(V-B)R(T)CV = const.
I got stuck here and checked the method. My process was right, but according to it, the next line of work is:
(V-B)R(RT)CV = const.
I don't understand where this mystery R comes from. I've tried rearranging the ideal gas equation, and the first given equation to no avail. Could someone please explain how I get this R in the process?
Thanks!
R is the universal molargas constant and is part of the definition of a van der walal gas, just as it is for an ideal gas.
I haven't worked this out completely, but I would:
let p1 = p + A/v2
v1 = v - B
then p1v1 = RT.
By your du = -dw and dT = (1/R)(p1dv1 + v1dp1) you can eliminate T, integrate by parts to get p1v1γ = constant.
I think.
I was too thinking the same.
All I can think of, for a simple solution, is that you multiply both sides by R^Cv (which in itself is constant since Cv=1.5R when n=1)
This is valid since the right side remains constant = constant times R^Cv
The left side is now what we require.
Thanks!
If you have
and you multiply both sides of the equation by RCV, you get
(V-B)R(RT)CV = (const.)(RCV) = New constant
Chet
  • · Replies 23 ·
13K
9K
