Easiest way for two men to lift a pipe
  • Context: High School
  • Thread starter Thread starter voyager221
    Lift Pipe
The discussion centers on the mechanics of lifting a pipe using a rope, specifically comparing the effectiveness of a loose rope versus a tightly knotted rope. It concludes that a loose rope allows for a more favorable angle (theta) which reduces the force required by each porter to lift the pipe. The mathematical relationship shows that the tension in the rope and the angle of lift significantly affect the effort needed, with the optimal angle minimizing the force exerted. The analysis indicates that a longer rope with a greater angle makes lifting easier due to the distribution of weight and tension.
  • Understanding of basic physics principles, particularly tension and force.
  • Familiarity with trigonometric functions, specifically sine and cosine.
  • Knowledge of mechanical advantage in lifting techniques.
  • Ability to interpret diagrams related to force vectors and angles.
  • Study the principles of mechanical advantage in lifting systems.
  • Learn about the role of angles in force distribution and tension management.
  • Explore the physics of pulleys and their applications in lifting heavy objects.
  • Investigate the mathematical relationships involving sine and cosine in real-world scenarios.
Physics students, engineers, and anyone interested in understanding the mechanics of lifting and force distribution in practical applications.
voyager221
If rope is wrapped around a pipe and two men are lifting it up why is it easier to lift when the rope is loose around the pipe (A) and harder when the rope is tied tightly to the pipe in a knot at both ends (B) ?
I presumed this was because on A the weight is less concentrated?
I'm guessing a bit at the diagram...
Rope attached to one end of pipe, rises at angle theta to horizontal to first porter, proceeds horizontal to second porter, descends at angle theta to attach to other end of pipe. And the question is, why does a longer rope (greater theta) make it easier on the porters?
Pipe weight W, tension in rope T = W cosec(theta)/2.
To balance the tension locally, each porter has to pull at angle theta/2 to vertical with force F = 2T sin(theta/2).
Thus F = W sec(theta/2)/2. This is minimised when theta is 0.
So it doesn't support your observation.
Maybe I have the diagram wrong.
  • · Replies 30 ·
  • · Replies 16 ·
  • · Replies 67 ·
24K
  • · Replies 31 ·
  • · Replies 18 ·
