Thread Closed
Electric potential/potential energy
Share Thread Thread Tools
Jan19-05, 07:39 PM   #1
Ok I have a couple questions here.
1. Calculate the speed of a proton and an electron after each particle accelerates from rest through a potential difference of 190V.
I think I got the part of the electron because I randomly came across the energy value of an electron. The equation I'm using is 1/2mv^2 = q(190V)
2. A hydrogen electron orbits its proton in a circular orbit of radius 0.529X10^-10 meters. What is the electric potential due to the proton at the electron's orbit?
V=kq/r right? But where do I find the q??
3. A uniform electric field E=7500 N/C points in the negative x direction. What is the distance between the +14-V and +16-V equipotentials?
I have no idea on this one.
Any help on any of these woulod be greatly appreciated. Thanks a ton in advance.
Eric
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Jan19-05, 07:47 PM   #2
part 1 looks right... you can do the same for a proton just don't forget to change the values of m and q.
part 2: thats the right equ'n... the q is referring to the source charge which in this case I believe to be the charge of the proton (should be in your book / same as e but opposite sign)
part 3: the equ'n for potential for a uniform electrical field is ED
Jan19-05, 08:04 PM   #3
Quote by MathStudent
For part 1 I just don't see how to get the q for the proton. I just stumbled upon it for the other part.
FOr part 2 the q value is definitely not in my book. I looked in all the appendices and everything.
For part 3 you're saying that V = ED?
Jan19-05, 08:19 PM   #4
Quote by triplezero24
Realize that the charge of the proton is equal to that of an electron but has the opposite sign (that is its positive)... I believe I said this in an earlier post
If you don't believe me remember that
[tex]\Delta V = \int\vec{E}\cdot\vec{dl}[/tex]
since [itex]\vec{E} [/itex] is constant , this can be taken out of the integral
and this becomes
[tex]\Delta V = \vec{E}\int\vec{dl} [/tex]
And since [tex]\int\vec{dl} [/tex] is just equal to the distance traveled by the particle
[tex]\Delta V = ED [/tex]
(where the above integrals are definite line integrals whose lower limit is the starting point and upper limit is the end point of the path )
Jan19-05, 08:20 PM   #5
[tex]\DeltaV = \int\vec{E}\cdot\vec{dl}[/tex]
and this becomes
[tex]\DeltaV = \vec{E}\int\vec{dl} [/tex]
[tex]\DeltaV = ED [/tex]
Sorry if it sounded like I didn't believe you. I just didn't fully understand you.
Jan19-05, 08:21 PM   #6
Thats fine.... you should question everything rather than take it at face value, its part of the learning process :)
PS: It should show a "Delta v" before each equals sign,,, is it showing up for you?
Jan19-05, 08:34 PM   #7
It doesn't show, but it makes more sense now. Thanks a bunch.
Thread Closed
Thread Tools
Similar Threads for: Electric potential/potential energy
Thread Forum Replies
Print ViewElectric Potential Energy versus Electric Potential Introductory Physics Homework 2
Electric potential, potential difference, and potential energy Introductory Physics Homework 2
Electric potential and electric potential energy question... Introductory Physics Homework 1
Confusion with Electric Potential/Potential Energy Introductory Physics Homework 1
Electric Potential/Electric Potential Energy question... Introductory Physics Homework 3
