A) Investigating Probabilities of X < 1
  • Thread starter Thread starter mah062
    Probabilities
The discussion focuses on calculating probabilities using the cumulative distribution function (CDF) for a random variable X. The values provided are F_{X}(1)=0.5, F_{X}(2)=0.74, and F_{X}(3)=0.92. For part A, the probability that X is less than 1 is calculated as 23.148% by dividing F_{X}(1) by the total sum of the CDF values. The discussion confirms that understanding the CDF is crucial for determining probabilities for the specified ranges.
  • Understanding of cumulative distribution functions (CDF)
  • Basic knowledge of probability theory
  • Familiarity with random variables
  • Ability to perform basic arithmetic operations
  • Study the properties of cumulative distribution functions (CDF)
  • Learn how to calculate probabilities using CDF values
  • Explore the concept of probability density functions (PDF)
  • Investigate applications of CDF in statistical analysis
This discussion is beneficial for students and professionals in statistics, data analysis, and anyone interested in understanding probability calculations using cumulative distribution functions.
mah062
1) (1 pt) You are investigating a random phenomenon and have determined that the cumulative distribution function F_{X}(x):=P(X<x) of the random variable X has values F_{X}(1)=.5, F_{X}(2)=.74, F_{X}(3)=.92
A) Less than 1 _____
B) Larger than 2 _____
C) Between 1 and 3 _____
2) Equations: None that I know of that pertain to this particular problem.
3) Part A:
0.5+0.74+0.92=2.16
So... 0.5/2.16=0.23148 Or 23.148%
I tried this for each part. I'm looking through my notes but they only have probability questions with equations.
2) Equations: None that I know of that pertain to this particular problem. 3) Part A:
0.5+0.74+0.92=2.16
You're given the cumulative distribution function (CDF). That gives the probability that X will be LESS than a given value x.
So what does [itex]F_X(1)[/itex] signify? The answer to part a) is immediate.
Can you now figure out the other two parts?
Solved. Thank you!
