Behavior of wire subjected by two equal and opposite pulling forces?
  • Context: Graduate
  • Thread starter Thread starter johnconnor
    Behavior Forces Wire
The discussion focuses on the behavior of a wire subjected to equal and opposite pulling forces, adhering to Hooke's law. The work done by the wire during extension can be calculated using the formula W = Te, where T is the tension and e is the extension at each end. The internal forces balance out for equilibrium, yet the wire extends due to the internal tension. The energy stored in the wire increases as strain energy, calculated using the formula PE = 1/2kx^2, where k is the force constant derived from the wire's properties.
  • Understanding of Hooke's law and its application in elastic materials
  • Familiarity with basic calculus for integrating force over distance
  • Knowledge of material properties, including elasticity modulus (E) and cross-sectional area (A)
  • Ability to apply energy conservation principles in mechanical systems
  • Study the derivation of work done in elastic materials using calculus
  • Learn about the relationship between stress, strain, and elasticity in materials
  • Explore the concept of plastic deformation and when cross-sectional area changes become significant
  • Investigate the implications of approximations in mechanical calculations, particularly in elastic systems
Mechanical engineers, physics students, and materials scientists interested in understanding the mechanics of materials under tensile forces and the principles of elasticity.
johnconnor
Imagine a wire with uniform circular cross-sectional area and length l. It is being pulled at both ends with a horizontal force that is equal and opposite to each other. The wire obeys Hooke's law up to breaking.
(1) How do we calculate the work done by the wire if both sides of the wire extend by 2e (i.e. an extension of "e" at each end of the wire)? (2) How do I explain the difference between the cancellation of the vector components of each force and the fact that the wire still extends? (3) What is the most proper way of writing down the mathematical working of the extension of the wire? On a side note, (4) How does the energy stored in the wire change, then?
(5) Also, in what cases are we supposed to assume that the cross-sectional area remains approximately the same and when do we not? (6) Is the approximation e^2 ≈ 0 necessary in this case when I'm calculating the energy stored in the wire?
Thank you for your help.
You can use [itex]W = \int F.ds[/itex], where F is the tension force and ds is the infinitesimal extension. Since the tension force varies from 0 to T during the extension of 2e, the integral works out to (T/2)(2e) = Te. Or if you don't like integrals, the wire is a spring with force constant k = T/2e (per Hookes law F=kx), so you can use energy methods [itex]W = \Delta PE = 1/2kx^2 = (T/(4e))(4e^2) = Te[/itex], same result.
The forces must be equal and opposite for equilibrium. Internally, the applied force T, at one end, must be equal to the internal force, T, in the rope, for equilibrium
extension = FL/AE, where F = the internal tension force and A is the wire cross section and E is the elasticity modulus (note that k=AE/L) , if that is what you mean
its strain energy increases due to the increase of its PE = 1/2kx^2
When the wire obeys hookes law in its elastic range, ignore any cross section change, which only becomes significant in the plastic range beyond yield when the wire will 'neck' down
as long as e is such that the wire still obeys Hooke's law, then the stored energy is valid. Since e is on the order of .001 L, I guess you are right that e^2 must be small
'welcome.
  • · Replies 19 ·
  • · Replies 36 ·
