Theoretical spring constant calculation for a tube of pipe
The discussion revolves around the theoretical calculation of the spring constant for a hollow tube, specifically a glass pipette intended for use as a cantilever tip in atomic force microscopy experiments. Participants explore methods to determine the appropriate diameter of the pipette to achieve a desired spring constant of 100 Newtons/metre, while considering the implications of tapering and bending the pipette.
  • Homework-related
  • One participant requests guidance on calculating the spring constant of a hollow tube and finding relevant information or software for the solution.
  • Another participant inquires about the intended use of the glass pipette, suggesting it may be used as a building column.
  • A participant explains the context of using the pipette as a cantilever tip and discusses the need for a specific spring constant, mentioning the ability to adjust the spring constant through tapering or etching.
  • Concerns are raised about the brittleness of glass for the application, with a suggestion to consider alternative materials.
  • One participant provides equations for calculating the moment of inertia and deflection of a cantilevered tube, noting that the calculations assume a straight beam of uniform cross-section.
  • Another participant asks for clarification on how tapering affects the calculations, specifically regarding the moment of inertia.
  • Further resources for reading on the topic are suggested, including links to online materials related to beam bending.
Participants express differing views on the suitability of glass for the application and the implications of tapering on the calculations. While some provide technical equations and insights, there is no consensus on the best approach or material choice.
Participants discuss the complexity of the calculations involved, particularly when tapering is introduced, indicating that the moment of inertia may change and that the situation may become more complicated than the initial assumptions suggest.
ReliableSin
I require the a means to theoretically calculate the spring constant of a hollow tube.
Essentially, I need to find the diameter of the glass pipette which will have a spring constant of 100 Newtons/metre. If someone could point me towards relevant information on calculating, or using software to find the solution it would be greatly appreciated.
This is what I need. I've been searching, but all I've been able to find are solutions based on spring geometry.
No idea.
Welcome to PF!
Hi ReliableSin! Welcome to PF! :smile:
I don't understand … what are you intending to do with this glass pipette? :confused:
Are you using it to support something, as a building column?
I'm using it as a cantilever tip in some atomic force microscopy experiments. Usually we fabricate our own cantilevers using optical fiber with a spring constant of ~100 Newtons/metre. Now we want to use a pipette as the cantilever tip. As such, we need the pipette to have a spring constant of about the same value. We can adjust the spring constant of the pipette by tapering or etching. However, we also need to make a bend in this pipette, and the thinner we make the pipette before bending, the higher the chance that our bend will stop fluid from flowing through the pipette.
To sum up, I need to know how to get the spring constant of a tube so I calculate what is the largest pipette diameter I can use which will have an appropriate spring constant.
I've been reading through the pages on wikipedia on spring constants and deflection. I think I need to find the appropriate moment of inertia for a cylinder, which is simple, and sub this into the equations given for a normal cantilever. However, I'm having a hard time following their math, specifically how they eliminate their force term.
No idea.
It does sound like glass will be too brittle for this application. Have you considered making the bending pipette out of some other material?
We use glass for these applications all the time. The issue is that the stiffness of a non-tapered glass pipette is too great to perform contact-mode measurements.
I'm assuming you have a cantilevered tube made of glass, but then you imply that the tube is actually tapered. If it isn't tapered, you can use straight beam equations:
I = 3.14159 (Do4-Di4) / 64
Where:
Do = OD
Di = ID
I is moment of inertia in units of length raised to the 4'th power.
Deflection of this beam is:
d = F L3 / (3 E I)
Where:
d = deflection (units of length)
F = Force
L = beam length
E = bending modulus (units of force per length squared)
To get spring constant:
k = F / d
k = 1 / ( L3 / (3 E I) )
This assumes the beam is tubular and straight and of uniform cross section and the force is perpendicular to the axis of the tube.
If the tube is actually tapered, curved, nonuniform cross section, etc... it will get a bit more messy...
Thank you so much! That's incredibly helpful. Could you point me towards your source for further reading on the topic?
And as you said, the tapering will modify these calculations. Will it essentially be a change of the moment of inertia, or is it more complex than that?
  • · Replies 24 ·
14K
  • · Replies 31 ·
  • · Replies 59 ·
11K
