Calculate electric field for cylindrical charge distributions
The discussion revolves around calculating the electric field for a long coaxial cable with a uniform volume charge density on the inner cylinder and a uniform surface charge density on the outer cylindrical shell. The problem involves determining the electric field in three distinct regions: inside the inner cylinder, between the cylinders, and outside the cable, while also considering the implications of Gauss' law.
  • Participants discuss the application of Gauss' law to find the electric field, questioning why the field due to the outer cylinder is considered zero inside the inner cylinder. There is also exploration of the implications of symmetry in the context of cylindrical charge distributions.
The conversation is ongoing, with participants providing insights and confirmations regarding the reasoning behind the electric field being zero in certain regions. Questions about the interpretation of flux and the nature of the Gaussian surface are being raised, indicating a productive exploration of the concepts involved.
Participants are navigating the complexities of applying Gauss' law to a cylindrical geometry, with some expressing uncertainty about the implications of infinite length on the behavior of the electric field and flux. The discussion reflects a mix of confidence and inquiry regarding the assumptions made in the problem setup.
aaaa202
(2.16) A long coaxial cable carries a uniform volume charge density ρ on the inner cylinder (radius
a) and a uniform surface charge density on the outer cylindrical shell (radius b). This surface charge is negative
and just the right magnitude so that the cable as a whole is electrically neutral. Find the electric field in each
of the three regions: (i) inside the inner cylinder (s < a), (ii) between the cylinders (a < s < b), (iii) outside
the cable (s > b). Plot |E| as a function of s.
2. Homework Equations
Gauss' law
3. The Attempt at a Solution
I am actually pretty confident at what to do except at one point. I can calculate the field inside the volume cylinder with Gauss' law. But by doing so I am not accounting for the field due to the surface of the outer cylinder. In my solutions manual it indeed seems that the field due to the outer cylinder is omitted - why is that? How can it be zero? I can certainly see it must be zero right in the center of the volume charge cylinder but why is it zero everywhere inside it?
Gauss' law
It is (a) because Gauss says so, and (b) because the electric field due to the charges on the outer surface cancel each other inside that surface. Not hard to show directly.
Gauss' law says that the field contributes nothing to the flux integral - how is that the same as saying the field is zero? But how would you show it. It is pretty obvious in the geometric center but what when you move away from that? Then you are closer to the upper part of the outer cylinder. I know for a fact that if you are inside a spherical shell, then the field is zero everywhere inside, but this is not spherical shell - it's cylindrical :(
You're smart to question whether the surface integral of flux being zero is the same thing as saying the E field is zero everywhere. But in this case it has to be because there is symmetry all over the circular part of your right circular cylindrical Gaussian surface, and, since the wire is very long (this is key!) there is no flux out the sides of your G. surface, so the field is the same all over the surface. And if it's the same all over the surface then it must be zero everywjere.
Thanks for the answer. I had more or less come to the same conclusion after having thought for a good while, but it's nice to get a confirmation of the correctness.
However, another question did pop into my head in the mean time. You say the flux is 0 out of the sides of the cylinder. I do realize that if you take any point in an infinite cylinder then you have a field going radially out, i.e. perpendicular to the sides. But how does it even make sense to then take of sides, if you are considering an infinite cylinder? It seems a bit ambigious to me.
Your Gaussian surface is a small section of an infinitely long r.c. cylinder. It's the sides of the G. surface that have no flux entering or leaving. If the whole cylinder were not infinitely long then your section of it would have some flux leaving the sides.
Capiche?
  • · Replies 18 ·
