Surface integrals of vector fields
The discussion revolves around the calculation of the flux of a vector field through a surface using surface integrals, specifically focusing on the parametrization of the surface and the implications of manipulating normal vectors in the context of the integral formula.
  • Participants explore the implications of multiplying the normal vector in the flux integral and question the validity of such operations. There is a discussion on the relationship between the normal vector, the surface measure, and the parameterization of the surface.
Participants are actively engaging with the concepts, questioning assumptions about the normal vector and its role in the flux calculation. Some have provided insights into the definitions involved, while others express confusion about the implications of changing the normal vector.
There is mention of specific formulas and the need for unique parameterizations within a coordinate system, indicating constraints in the problem setup that may affect the discussion.
cjc0117
The integral for calculating the flux of a vector field through a surface S with parametrization r(u,v) can be written as:
[itex]\int\int_{D}F\bullet(r_{u}\times r_{v})dA[/itex]
But what's to stop one from multiplying the normal vector [itex]r_{u}\times r_{v}[/itex] by a scalar, which would result in a different flux? When you're asked to find the flux of a vector field through a surface, how do you know which scalar to use?
dA is du*dv, right? That's your formula. It doesn't say you can multiply the normal vector in the formula by an arbitrary number. Why would you do that?
I got confused because I was trying to solve a problem where you had to use Stoke's theorem to find the flux of the vector field <2x,3y,z3> through the curve of intersection of the paraboloid z=x2+y2 and the plane 2x+4y+z=1, when C is traversed conterclockwise when viewed from the origin. So I found the curl to be <0,0,5>, the normal to the plane <2,4,1> and the region D traced out by the curve C to be a circle of radius sqrt(6). The flux I think is just -<0,0,5>*<2,4,1>π(sqrt(6))2=-30π. But then I started thinking, since any normal can be used to find the scalar equation of a plane, why can't the normal <2,4,1> be multiplied by, say, 2 to get <4,8,2>. It'll still be normal to the plane, right? Then the flux would be -60π. But now that I think of it more, that doesn't make sense, since the normal vector was derived from the scalar equation of the plane, which dictates that the normal vector be <2,4,1>.
Your formula uses a specific normal vector and a specific surface measure dA=du*dv. Sometimes you do it with a unit normal vector and a different notion of surface measure. The two are interrelated. You can't change one without changing the other.
Thank you. So it can't be changed just by virtue of the definition of the differential dS=(ru x rv)dudv, which relies on a unique parameterization r(u,v) (or at least unique within the scope of a single coordinate system)? I really don't understand why this was troubling me; I must have been very tired last night.
