Smooth Homotopy, Regular Values (Milnor)
  • Context: Graduate
  • Thread starter Thread starter Sina
    Regular Smooth
The discussion revolves around the concepts of regular values and smooth homotopies in the context of differential topology, specifically referencing Milnor's work. Participants explore the implications of regular values, the nature of smooth homotopies, and the treatment of empty fibers in these contexts.
  • One participant questions the definition of regular values, noting that regular values with empty inverse images are often disregarded, which may create issues in understanding their density for smooth functions.
  • The same participant presents a specific example involving a homotopy of the unit disk and questions its smoothness, suggesting that the range of the homotopy may not be adequately addressed.
  • Another participant suggests that the failure in the original example may stem from applying theorems about manifolds without boundaries to a manifold with a boundary, specifically the unit disk.
  • A later reply clarifies that the empty set is considered a manifold of every dimension and a regular value, implying that the treatment of empty fibers is consistent with manifold definitions.
  • One participant expresses surprise at the notion of empty sets being considered regular values and indicates a desire to further explore this concept.
Participants exhibit some disagreement regarding the treatment of regular values and the implications of empty fibers. There is no consensus on the initial claims about smooth homotopies and their definitions, as well as the application of theorems to manifolds with boundaries.
Participants acknowledge limitations in their understanding of the definitions and properties of regular values, particularly in relation to empty inverse images and the implications for smooth homotopies. The discussion reflects a need for clarity on the application of theorems to different types of manifolds.
Sina
Hello, I have a question regular values and smooth homotopies. Usually in giving the definition of regular value, they disregard the regular values whose inverse image is empty set (although they should be called regular values if we want to be able to say that set of regular values is dense for smooth functions :)). Also given a map f: M [itex]\rightarrow[/itex]N a map from some m-dimensional manifold to n-dimensional manifold, and y a regular value [itex]f^{-1}(y)[/itex] is said to be m-n dimensional submanifold and when stating this, they also disregard regular values whose inverse image is the empty set. Now this seems to create a problem, or maybe I am wrong.
Consider the example in milnor's book where he says a orientation reversing diffeomorphism of a compact boundaryless manifold can be smoothly homotopic to the identity (because homotopic maps have same index).
As M and N I take the unit disk [itex]D^2[/itex]. Consider the "homotopy" F: [0,1] x [itex]D^2[/itex] [itex]\rightarrow[/itex] [itex]D^2[/itex]
F(x,y,t) = (x, -1(1-t)y +ty). F(x,y,0) = (x,-y) and F(x,y,1) = (x,y) . First of all why is this not a smooth homotopy. Yes as t changes, range becomes a subset of unit disk and infact at t=1/2 it is the intersection of the unit disk with the y=0 line but nothing is said about the range of maps in smooth homotopy.
Moreover, DF = [1 0 0 ; 0 2t-1 2y] so that for instance z=(0,-1) is a regular value whose inverse image is the two points (0, 1,0) and (0,-1,0). But since z is a regular value shouldn't this be a 1-dimensional submanifold? I think the problem here arises because intersection of [itex]f^{-1}(z)[/itex] with the sets t x [itex]D^2[/itex] is empty for t not equal to 0 or 1.
Thanks
In your second paragraph, do you mean to say
"Consider the example in milnor's book where he says a orientation reversing diffeomorphism of a compact boundaryless manifold cannot be smoothly homotopic to the identity (because homotopic maps have same degree)." ?
If so, then perhaps what fails in your example is not so much the smoothness of your map as it is the fact that D² has a boundary. And if you remove the boundary, you lose compactness.
In your last paragraph, you seem to be again applying a thm about manifolds without boundary to a manifold with boundary.
Yes indeed I meant degree (and Brouwer degree). and yes I later realized disk is with boundary. and if you try to take circle or torus it does not work so everything seems okay =) thanks for the reply
People do not disregard empty fibers. rather note that by definition the empty set is a manifold of every dimension, and also a regular value. i.e. whatever has to be true for every point is certainly true for the set with no counterexamples.
Ha I actually never thought of empty sets as such thanks for the enlightening comment :) I will think and research more about it
  • · Replies 20 ·
  • · Replies 36 ·
  • · Replies 0 ·
  • · Replies 21 ·
