| New Reply |
Parameterizing z-value of Cylinder in Line Integral Projection (Using Stokes Theorem) |
Share Thread | Thread Tools |
| May10-12, 07:05 AM | #1 |
I am a little confused about how to generally go about applying Stokes's Theorem to cylinders, in order to calculate a line integral. If, for example you have a cylinder whose height is about the z axis, I get perfectly well how to parameterize the x and y components, using polar coordinates, for example, but what about z (and thus dz)? If you have a vector field that is dependent on z, such as F= (z,x,yz) (it doesn't matter which, I am just listing one for clarity) and you want to replace with polar coordinates, what approach do you take with z, when projecting your surface about a closed loop?
What confuses me is if you have a sphere, or something similar, you find the shadow of the surface, which is effectively the z-value where the circumference is widest-- but with the cylinder, all z-values are at locations with equal circumference about the x-y plane. Is it the bottom? Top? Somewhere in between? Thanks!!! |
| May10-12, 10:54 AM | #2 |
Recognitions:
It isn't clear to me what sort of problem you are describing. Can you give a specific example or post a link to such a problem on the web?
When you talk about "the components" in your original post, you aren't making it clear whether you mean the components of a vector field F(x,y,z) or whether you mean the components of a vector that describes the surface involved or whether you mean the components of the vector that traces out the curve to used for the line integral. |
| May10-12, 11:10 AM | #3 |
Well, parameterizing x=cos(t), y=sin(t) seems logical, and dx and dy follow from these. But I don't know what to do with z. If this were a sphere, you could just rewrite z in terms of x and y, or by some other method. But I don't know what to do with it when it is with a cylinder. |
| May10-12, 11:37 AM | #4 |
Recognitions:
If you dealing with a curve in the xy plane, you set z = 0. Perhaps I don't understand what curve you want to use in the line integral.
| May10-12, 12:07 PM | #5 |
This is where I am getting confused: If it were the same problem, but the surface was the part of z=9-x^-y^2 that lies above z=5, you would still parameterize C the same way with x and y, but for z, you would set it equal to 5, right? That is the only way I have seen that type of problem, so I assume it is either the only way to do it, or the best way to do it. But with a cylinder, do you have more flexibility parameterizing C (and thus choose z=0)? What if the cylinder's base were at z=5 and went up from there (so that z=0 was not inside your surface)-- does that change anything, or can you still project your curve so that z=0? I really appreciate your help! |
| May10-12, 01:03 PM | #6 |
Recognitions:
If you have cylindrical surface about the z-axis (one that has a top) which is bounded below by the plane z = 5 then you can apply Stokes theorem to the curve where it intersects that plane. On that curve you set z = 5. |
| New Reply |
| Thread Tools | |
Similar Threads for: Parameterizing z-value of Cylinder in Line Integral Projection (Using Stokes Theorem)
| Help doing an integral using stokes theorem? | Calculus & Beyond Homework | 1 | ||
| "Stokes theorem" equivalent for cross product line integral | Calculus & Beyond Homework | 4 | ||
| (vector calculus question using stokes theorem and line integrals with respect toarc | Calculus & Beyond Homework | 0 | ||
| stokes theorem and line integral | Calculus & Beyond Homework | 2 | ||
| Line Integral (Stokes Thm) | Calculus & Beyond Homework | 2 | ||
