Elevator Physics: Block on Wedge, a=2m/s^2, μ=0.1
  • Thread starter Thread starter Perpendicular
    Elevator Physics
The problem involves an elevator descending with an acceleration of 2 m/s², which has a wedge inclined at 30 degrees. A block is released from the top of the wedge with zero initial velocity, and the task is to determine how far the block travels along the incline after one second, considering a coefficient of friction of 0.1.
  • Exploratory, Assumption checking
  • Participants discuss the interpretation of the elevator's acceleration, questioning whether it should be considered as 2 m/s² or g + 2 m/s². Some explore the implications of both cases on the block's motion.
The discussion is ongoing, with various interpretations of the problem being explored. Some participants have provided insights into the normal force and effective weight within the elevator, while others emphasize the need for clarity in the wording of the problem.
There is a noted ambiguity regarding the acceleration of the elevator and its impact on the calculations. Participants are also considering the effects of friction and the angle of the incline in their reasoning.
Perpendicular
an elevator descends with a = 2m/s^2. there is a wedge on it. the wedge has an angle of 30 degrees. at the top of the incline of the wedge a small block is released with zero initial velocity from the elevator's frame of ref. after 1 sec, how much does the block travel along the incline of the wedge with respect to the wedge , given co-efficient of friction is 0.1 ?
N = mgcos30, friction = co-efficient of friction x N
the main problem I have is with the wording...does it mean that the elevator is going at g+2 m/s^2 or 2 m/s^2 ? I assumed the latter as the former would result in the wedge colliding with the top of the elevator.
what would happen in case A and case B ? would the results be different ?
First you have to find Normal force.
If you weigh yourself in the elevator descending at 2m/s2, what's the reading.
Now take it as if you're on this Earth with different g.
An elevator normally has a counterweight, that travels in the opposite direction as the car. The counterweight in all the elevators that I've worked on is heavier than an empty car, but a loaded car might be different. So the car would have an effective weight of whatever the difference between the car and the counterweight is. So in a real elevator, would the car stop much more quickly?
I'm guessing the counterweight is the reason that the acceleration of the car is so much smaller than g, but the fact that the acceleration is as large as it is would indicate that it is probably overloaded.
well, taking g = 10 to simplify, we get an effective within-elevator g of 8, and since acc. down the slope = gsin30 or 4, minus the acceleration loss due to friction, you get a net acceleration of approximately 3.3 m/s^2 down the slope, resulting in about 1.65 meter moved in 1 sec.
this assumes that acceleration of elevator is 2, not g+2...it's more of a wording issue really. should I assume it to be g+2 or 2 ?
Why would you assume that the acceleration is anything other than the number they give you? (Not to mention that an elevator descending at 12 m/s would be quite a shock to the riders!)
Quite clearly, acceleration of the elevator is 2 m/s2 downwards and not (10+2)m/s2. :smile:
Taking downward as positive
a=acceleration of elevator
Mg-N=Ma
N=M(g-a)
Mg'=M(10-2)
g'=8
Evaluation:
If the acceleration downward is equal to g, the apparent weight will be zero(g'=0), free fall.
If a>g then everything inside the elevator is flying up(negative =motion-up).
  • · Replies 55 ·
12K
