- 4,663
- 36
Thomas Hobbes on "Sense"
Hi, I could use a hand with this.
I am not clear on how Thomas Hobbes (in Leviathan, Part I - Of Man) is explaining the cause of certain senses.
My book explains it this way:
"According to Hobbes, sensations are caused by the pressure of external objects on the sensory organs. In the case of taste and touch this pressure is direct, whereas in the case of hearing, vision and smell, the sensation is transmitted via motions in the surrounding air."
My question is: if Hobbes is saying that motions in the air are transmitting the sensation, does he mean that the motions are pushing particles in the air around and then those particles in turn strike the sensory organs causing the sensation? Does anyone understand what is meant by "mediation" in the passage below?
here's it is:
Thanks,
MIH
here's it is:
The cause of sense is the external body, or object, which presseth the organ proper to each sense, either immediately, as in the taste and touch; or mediately, as in seeing, hearing, and smelling: which pressure, by the mediation of nerves and other strings and membranes of the body, continued inwards to the brain and heart, causeth there a resistance, or counter-pressure, or endeavour of the heart to deliver itself: which endeavour, because outward, seemeth to be some matter without. And this seeming, or fancy, is that which men call sense; and consisteth, as to the eye, in a light, or colour figured; to the ear, in a sound; to the nostril, in an odour; to the tongue and palate, in a savour; and to the rest of the body, in heat, cold, hardness, softness, and such other qualities as we discern by feeling. All which qualities called sensible are in the object that causeth them but so many several motions of the matter, by which it presseth our organs diversely. Neither in us that are pressed are they anything else but diverse motions (for motion produceth nothing but motion).
borrowed from: http://www.constitution.org/th/leviatha.htm
Thanks,
MIH
