Find if Parametric equations are perpendicular
The discussion revolves around determining whether two given parametric equations represent lines that are perpendicular to each other. Participants explore the mathematical conditions for perpendicularity in the context of parametric representations, focusing on vector direction and the dot product.
  • One participant questions whether constant terms in the parametric equations affect the determination of perpendicularity, suggesting that they can be omitted to simplify the analysis.
  • Another participant emphasizes the need to find the direction vectors for both parametric equations to test for orthogonality using the dot product.
  • A participant expresses a conceptual clarification that "perpendicular" is a term defined for geometric objects, not equations themselves, but acknowledges the intent to assess the lines represented by the equations.
  • A later reply outlines the condition for perpendicularity in terms of the dot product of the direction vectors, stating that the vectors are perpendicular if their dot product equals zero.
Participants appear to agree on the mathematical approach involving direction vectors and the dot product, but there is some contention regarding the interpretation of perpendicularity in relation to equations versus geometric lines.
There are unresolved assumptions regarding the treatment of constant terms and the definitions of perpendicularity in the context of parametric equations versus geometric lines.
salistoun
Hi all,
How do you find out if this Parametric equation
x = -2t + 3 ; y = -t - 1 ; z = -3t + 2
Is perpendicular to this parametric equation
x = -2 + 6t ; y = 3 - 6t ; z = -3 - 2t
Thanks
Stephen
The constant terms won't affect it, will they? I.e., can't you replace each line by one parallel to it through the origin, and do that simply by omitting the constant terms?
Then it will be just a matter of checking that the dot product of the two 3-d vectors is zero.
salistoun said:
Hi all,
Thanks
Stephen
Hey salistoun.
Do you know how to get the direction vector for both parametric representations? How can you test whether two vectors are orthogonal with the dot product?
I was sorely tempted to say that equations, whether parametric or not, are never perpendicular- "perpendicular" is only defined for geometric objects.
But you mean "are the lines given by these parametric equations perpendicular".
The line given by parametric equations [itex]x= A_1t+ B_1[/itex], [itex]y= C_1t+ D_1[/itex], [itex]z= E_1t+ F_1[/itex] and [itex]x= A_2t+ B_2[/itex], [itex]y= C_2t+ D_2[/itex], [itex]z= E_2t+ F_2[/itex] are perpendicular if amd only if their direction vectors [itex]<A_1, C_1, F_1>[/itex] and [itex]<A_2. C_2, F_2>[/itex] are perpendicular which, again, is true if and only if their dot product, [itex]<A_1, C_1, F_1>\cdot<A_2, C_2, F_2>= A_1A_2+ C_1C_2+ F_1F_2= 0[/itex].
