Finding Limits of Sequences: How to Determine N Values for Given Conditions
  • Thread starter Thread starter courtrigrad
    Limits Sequences
The discussion revolves around finding limits of sequences, specifically focusing on the sequence defined by a_n = n/α^n, where α is greater than 1. Participants explore how to determine specific values of N such that the sequence remains below certain thresholds as n increases.
  • Participants discuss the need to find minimum values N_1, N_2, and N_3 for which the sequence a_n is less than specified values (1/10, 1/100, 1/1000) for n greater than these N values. There is a mention of using guess and check methods versus deriving values from the sequence's behavior.
Some participants have suggested using inequalities to derive N values, while others are questioning whether the approach should involve guess and check methods or more formal proofs. There is an ongoing exploration of how to apply epsilon-delta definitions in this context.
Participants note that the problem is derived from a textbook and express a desire to understand the reasoning behind the values they calculate or derive. There is also mention of the potential complexity of the limits as ε becomes smaller.
courtrigrad
Hello all:
Given [tex]a_n = \frac {n}{\alpha^n}[/tex] and [tex]\alpha[/tex] is a number greater than 1, we assert as n increases the sequence of numbers [tex]a_n = \frac {n}{\alpha^n}[/tex] tends to the limit 0.
Let us consider the sequence [tex]\sqrt a_n = \frac {\sqrt n}{(\sqrt \alpha)^n}[/tex]
We put [tex]\sqrt \alpha = 1+h[/tex] where [tex]h > 0[/tex]
[tex]\sqrt \alpha^n = (1+h)^n > 1+nh[/tex]
[tex]\sqrt a_n = \frac {\sqrt n}{(1+h)^n} \leq \frac {\sqrt n}{1+nh} \leq \frac {\sqrt n}{nh} = \frac {1}{h\sqrt n}[/tex]
[tex]a_n \leq \frac {1}{nh^2}[/tex] and [tex]a_n \rightarrow 0[/tex]
Now my question is: Suppose you are asked to find numbers [tex]N_1, N_2, N_3[/tex] such that
(a) [tex]\frac {n}{2^n} < \frac {1}{10}[/tex] for every [tex]n > N_1[/tex]
(b) [tex]\frac {n}{2^n} < \frac {1}{100}[/tex] for every [tex]n > N_2[/tex]
(c) [tex]\frac {n}{2^n} < \frac {1}{1000}[/tex] for every [tex]n > N_3[/tex]
Do I have to guess and check for these numbers or can I somehow use the proof of this sequence? Because what if [tex]\epsilon[/tex] becomes smaller and smaller? Then there must be some method to find [tex]N_1, N_2, N_3[/tex]
Thanks a lot for any help or advice
EDIT: Its [tex]\frac {n}{2^n} < \frac {1}{10}[/tex] for every [tex]n > N_1[/tex] and the same with the others
In your case here: [tex]\alpha = 2[/tex] Solve for h.
You want [tex]a_n<\frac{1}{10}[/tex]. If you know that [tex]\frac{1}{nh^2}<\frac{1}{10}[/tex] then that means that [tex]a_n<\frac{1}{10}[/tex].
So from [tex]\frac{1}{nh^2}<\frac{1}{10}[/tex] you can get the n value you need. This will give you an N1 such that if n>N1, [tex]a_n<\frac{1}{10}[/tex]
But are you looking for the minimum N1 such that if n>N1 then [tex]a_n<\frac{1}{10}[/tex], or are you just looking for any N1 such that if n>N1 then [tex]a_n<\frac{1}{10}[/tex]? If you're looking for the minimum N1, then you might want to want to calculate [tex]a_{N1}[/tex] and make sure that it is >=1/10.
i am looking for the minimum [tex]N_1[/tex]
I know that for part (a) [tex]N_1 = 6[/tex] buy why?
Thanks
Then I think you'd just have to plug it in and check.
Are you trying to do an epsilon-delta proof to show that the limit is 0? Then it is sufficient to show that for every epsilon>0, there is some N such that for n>N |a(n)-0|<epsilon or in other words show that a(n)<epsilon. I'm guess that the 1/10, 1/100 are different choices for epsilon?
any other ideas?
thanks
so i take it that the only way to find the smallest numbers would be by guess and check? Because after solving for n i get 64.
This is from Courant's book by the way (i am a high school student)
Thanks
Thanks anyway for your help
Same concept Different Limit
Ok so let's say we have [tex]a_n = \sqrt n+1 - \sqrt n[/tex] and we want to find numbers [tex]N_1, N_2, N_3[/tex] such that
[tex]\sqrt n+1 - \sqrt n < \frac {1}{10}[/tex] for every [tex]n > N_1[/tex]
[tex]\sqrt n+1 - \sqrt n < \frac {1}{100}[/tex] for every [tex]n > N_2[/tex]
[tex]\sqrt n+1 - \sqrt n < \frac {1}{1000}[/tex] for every [tex]n > N_3[/tex]
Now since [tex]\sqrt n+1 - \sqrt n = \frac {(\sqrt n+1 - \sqrt n)(\sqrt n+1 + \sqrt n)}{\sqrt n+1 + \sqrt n} = \frac {1}{\sqrt n+1 + \sqrt n}<br /> <br /> How would i obtain [tex]N_1, N_2 ,N_3[/tex]?<br /> <br /> PS: I know if I solve the equation I get <b> a </b> [tex]N_1 N_2 N_3[/tex] but I want to get the least of all of them<br /> <br /> Any help is appreciated (as with the first one do I just guess and check?)<br /> <br /> Thanks[/tex]
hmmm, i i think i have to substitute values in lless than the solved value?
thanks
  • · Replies 21 ·
  • · Replies 63 ·
  • · Replies 17 ·
  • · Replies 16 ·
